Got the add a leafs in the packs and back on my jeep. I did this in order to eliminate the lift block on the axle for the budget boost it is running. Rear end seems to sit higher and I have pretty much no shackle angle. They are straight up and down. I'm running factory shackles. I left the shackle top bolt loose and both spring eyebolts till it was on the ground. Torqued the top shackle bolt and main eye to 100ft lbs and the shackle spring eye to 80 ft lbs.
