xDUMPTRUCKx
- highway to hell
right now shaft failure is pretty much not an option.
ive got CTM 35 spline 300m inners & outers with 300m drive slugs.
not too worried about shaft breakage with 40s and a 4.0 5.38s and a 4:1 rubi tcase.
vetteboy said:A Detroit rarely fails by itself. Usually they break because something else exploded and shock-loaded it.
In that sense, the Lock-rites tend to hold up better. People break shafts with lock rites and have no problems with the locker blowing up. However I have heard of more isolated failures with the lock rites themselves breaking, as well as the stock carrier.
The 40-spline D60 detroit will only make things worse because there's less material in the side gears, and the piece that really explodes is the same in all the D60 models...but you'll be less likely to break a 40-spline shaft in the first place.
