Throws
- Portland, OR
This just happened clear out of the blue over the last few days. It started with hearing the starter getting hung up when starting (grinding noise), to taking a few tries to start. Here we are a few days later, and nothing.
Where we're at: Newer battery, newer starter (verified good), new power wires (.6ohm over the whole length). Starter relay was swapped into a different spot and works. Fuses all look good (maxi and mini). JUST replaced the ignition switch. No change. If you put it in to reverse, you get backup lights. Tried jiggling shifter and trying to start in neutral, nothing.
Any ideas?
-P
Any ideas?
-P
