shelbyluvv
- 29 Palms, CA
I have the rear defog/OD board out of a 93 ZJ. I am trying to mimic this on my MJ with a 5.2 Magnum.
I have blacked out all of the rear defog circuits. All I need is the OD circuit layed out. My plan is to use a WJ shifter with the OD off button on it. I also want to use the Shift light on a 94 XJ dash cluster. I will use an LED bulb in the socket.
Back of the board
Front of the board
D2 is a diode (what kind?)
R2 is a resistor (what kind?)
SW2 is the OD switch
LE2 is the OD Off LED
I'll only be using pins 4-7 for the power and what not.
PIN 4 is fused power
PIN 5 is Trans OD lamp PCM 37
PIN 6 is Trans OD pressure on PCM 10
PIN 7 is ground
I have a good idea of how it works but I do not know anything about resistors and diodes.
Can someone pleas lay this out and tell what diode and resistor I need?
Back of the board
Front of the board
PIN 7 is ground
