The stock t-case is most likely in need of replacement. If you turn tight on hard surface and it bucks, the VC is toast in the t-case.
Check for rot under the body covers (cladding, skirts).
Another problem they will all eventually have is the Plenum Plate gasket blowing out. It's not that bad of a fix but just be aware of it. This can cause some pinging and worse MPG's than it already gets as well as some oil consumption. You can check this by popping off the air hat and looking through the TB to see if there is any pooling oil in the intake plenum.
Last thing is make sure the owner was using premium fuel.
Besides that...check all the normal things you would with a 15+ year old jeep.
plenum gasket is probably blown.
drivers (sometimes passenger side too) heating element stops working.
the VIC usually breaks solders and says that you have problems that you don't and can get annoying.
if either of the cooling fan temp switches dies, they are near impossible to find.
other than that they are fun and quick for an old jeep
I replaced the plenum gasket, made a big difference.
Also swapped in a 242 as the VC was shot.
Driver side heated seat hasn't worked in a few years.
I've rebuilt the D44a rear twice.
Replaced the radiator fan motor; some Ford motor bolts right in place of it so you don't have to replace the entire assembly, which is expensive. On mine the low-speed winding crapped out so if you had the A/C going in traffic, it wouldn't blow air over the condenser, and the system wouldn't work right.
Aside from that, it runs great, gets 14.5 MPG on premium, and is a comfy and fast cruiser. Pretty much what everyone else has said.
every 5.9 we have gotta at work has had the rear lower control arms seperated from the body...I assume from the Northeast rust as well as people beating on it
