jeep parts list
MATTVW65
Layton Utah
http://www.ksl.com/index.php?nid=218&ad=24828997&cat=656
i have 3 jeep cherokees that i am parting out
this is a short list. if there is something I have that you might need or are looking for call or text me at 801-725-0112.
Matt
1999 4.0 engine $900 complete 134k still in jeep if you would like to hear it run
1997 4.0 engine compleate $900 97k still in jeep if you would like to hear it run
1999 4.0 engine compleate $800 pulled and ready to go 140k
2000 aw4 transmission $200
1999 aw4 transmission $200
1997 axi5 transmission $450
2000 231 transfer case $200
1999 231 transfer case $200
1999 231 transfer case $400 with a advanced addaptor sye kit
1999 dana 30 3.55 gears $200
2000 dana 30 3.55 gears $200
1999 dana 30 4.10 gears $300 with custom 1 ton stearing
2000 8.25 rear axle limited slip 3.55 gears $200
1999 8.25 rear axle open 3.55 gears $200
1999 dana 35 rear axle 3.55 gears $150
2000 dana 35 rear axle 3.55 gears $150
1988 jeep Cherokee rear Dana 44 3.55 gears $450
radiator's $40 ea
1997 rear overhead speaker tray $50
1999 rear hatch $75 black
2000 rear hatch $75 green
2000 xj drivers side seat $100
passenger $50
rear 2000 seat $40
1997 xj front seat drivers $100
passenger $50
2000 xj drivers side seat tan $100
passenger $50
1999 overhead console $200 complete
long arm lift kit 5"on black 99 $500 you remove
32X12.50 15 bfg allterrains $400
3" skyjacker lift kit on gold 99 jeep $400
steering gear box $40
dash cluster 97+ $50
teraflex 2" lift shackles $50
skyjacker bump stop set $10
transfer case drop kit $10
full s.s.t custom built sway bar disconnect set $75 for 5" to 8" lift
rear lift blocks 3" $15
rear drive line $20
starter $25
ft drive lines $40 each
cross over steering arms $40 Chev flat top
matt
text is best
801-725-0112
Grrrrrrrrrrrrrrrrrrrrrr......I just wanted to vent and piss and moan for a moment because there's so much from this list that I want, but it's not fiscally sound to make the drive from CA. (I ended up here, because my buddy just moved to Utah, so I was just looking what was going on in his new neck of the woods)
Carry on..
Updated list :)
this is a short list....... Really it is if there is something I have that you might need or are looking for call or text me at 801-725-0112.
Or pm me here
Matt
1999 231 transfer case $400 with a advanced adaptor sye kit
2000 8.25 rear axle 3.55 gears $200
passenger $50
rear 2000 seat $40
passenger $50
Passenger $50
3" skyjacker lift kit on 99 jeep $400
skyjacker front bump stop set $10
rear drive line $20
starter $25
matt
text is best
801-725-0112
