cheapcherokee93
<----boat-manche
- Guadalahabra, CA
no i know i can't readily assume its the RMS, but based on the symptoms it sure sounds like its contributing. it may not be the whole reason why its leaking, but i feel it is contributing. think about it, go up hill, leaks out a quart. go down hill leak out hardly any. sounds a lot like an leaky RMS would make sense no?
and the CCV shouldn't be plugged at all, remember the lines are all brand new and i have cleaned the inside of the valve cover including the reed valve for the CCV. i'll try to get a compression test done tomorrow to see if its a blown piston ring or not
