99NCXJ
- Belmont, NC
Here is a new and updated list of everything i've got up for sale.
Parts are in Clover, SC or can bring small parts to Belmont, NC.
Considering trades for: 4.56 gears for D30/8.25, D30 locker, 35" tires/wheels, or what ever else you think i might need!
1994 YJ frame, set up for radius arms in front, set up for cherokee leafs in back with ruff stuffs way back shackle hangers. Title available. 300.00
Ford Bronco full width hp D44 and 9" axles. new hub bearings on the 44, complete with calipers and rotors, needs drivers side shaft, open, cast wedges, 9" is complete drum to drum with spool. 350.00
1994 Jeep 5.2L v8 engine. from 94 grand cherokee limited, ran good when pulled. complete with full wiring harness and computer. miles unknown...just can't remember. 350.00
1994 YJ tub. has been in fire and needs to be blasted down to good metal and painted. structually is in good shape but not pretty right now. Right rear corner has some nice dents. 200.00
YJ hood-rusted like the tub and has some warping 35.00
YJ Grill- perfect condtion, silver, has all lights 150.00
YJ tail gate a little bent up. Not bad… 15.00
yj power steering box (4 bolt style) 50.00
YJ double battery tray. a little rusty, 15.00
YJ brake booster and master cyl. 25.00
YJ master cyl. 10.00
YJ tail light and a few extra covers 5.00
YJ seat risers painted black, look nice. 35.00
YJ steering shaft…a little tight. 10.00
YJ 2.5L antifreeze overflow tank. 5.00
stock zj coils 30.00/pair
zj glove box and door 15.00
zj radiator support 25.00
zj transmission cooler 20.00 SOLD
zj washer fluid tank. 5.00
zj steering column with steering wheel and air bag 50.00
zj steering shaft 10.00
zj over head console 20.00
zj headlights 15.00
zj dash controlls 15.00
zj leather rear seat. 60/40 split, tan leather. 30.00
zj gauge cluster with bezel 30.00
zj radiator support (5.2L) with hood latch 25.00
zj bezel for gauges 10.00
zj gas pedal assy. 10.00
zj brake pedal assy. 10.00
zj transfercase shifter assy. 10.00
zj polly gas tank (was going to be used as fuel cell) 50.00
zj brake booster and master cyl. 25.00
zj air box…5.2L 10.00
zj front door glass. Driver and pass. Side. 10.00 each.
stock xj leafs 50.00
ford radius arms 50.00
np242 100.00 SOLD
42re tranny, needs rebuilt 40.00
BA10 tranny, needs bellhousing 40.00
lower coil buckets for radius arms 10.00
(2) Dana 44 diff covers 10.00 each.
TJ stock front springs 25.00
2” by 2” steel cross member for anti-wrap bar. Has shackle hanger for mini shackle-made to fit YJ frame.15.00
Pair of xj front seats. light grey. 50.00
4.2L water pump 25.00
4.2L head with valves 30.00 SOLD
4.2L oil pan 20.00 SOLD
4.2L cam shaft 25.00
4.2L power steering pump 25.00
4.2L block 40.00
radiator for 318 zj motor 50.00
15 by 7 steel wheel. 5 on 5.5 (think it is a geo tracker wheel) 10.00
zj headlights 15.00
np242 100.00 SOLD
4.2L block 40.00
