xjcjfreek
- Northern BC Canada
Have any of you considered using the coils off an 72 vw beetle with the coilovers, as a homebuilt dual rate spring. I measured the coils on the vw today and its only about 1/4 inch smaller in size compared to an 86 xj coil. If you clamped them together you would come out with a dual rate spring that im guessing would generate about 6-8 inches of lift if not more. Also you could cut down the vw coil to obtain the desired lift. Any thoughts.:dunno:
