Pharaoh XJ
- Cairo, EGYPT
Gojeep why didnt you set the Taurus fan to run on low speed all the time and switch to high with the AC fan ?
What year Taurus are you comparing it too? They vary a lot according to the year and what engine also the Taurus had.BlackJax said:All I know is the mark viii will blow a valve cover across my garage floor. The taurus is no where near doing that. Also, the mark viii fan makes 100X the noise the taurus fan does. lol
Because why would a wear the fan out in a hurry by doing that as well as the extra drag on the alternator for supplying the extra current needed as well? You would negate every advantage almost the a electric fan has by running it all the time. There is absolutely no need for a fan during warm up and also as soon as you are driving faster then 30 mph. I have gone 4 months without even a fan turning on during the cold months and not running in heavy traffic.karim_gabra said:Gojeep why didnt you set the Taurus fan to run on low speed all the time and switch to high with the AC fan ?
88-xj-laredo said:
That's the one I did, and it works great, even at 105* in Las Vegas rush-hour traffic with the a/c on max. The key is in how well you work-out the shrouding.
Old thread I know but one thing I just don't get. The stock clutch fan pulls 5400CFM. That kit on angelfire give you 3 fans at 800 CFM each = 2400CFM.
How do those electric fans make it cooler when they pull less air?
Thanks
That's not the kit I used -- I modified a high CFM e-fan to fit in the stock shroud, kept the stock e-fan, and wired them to work in tandem thermostatically or by a switch on the dash.
1) Are you sure you have the correct clutch fan CFM data? Seems kinda' high...
2) I had sealed-off all of the possible 'leaks' so that ALL entering air was being pulled through the radiator.
3) Once engaged, e-fans turn at maximum CFM. I would think you'd have to be revving pretty high to reach equivalent CFM stock.
With this set-up I once climbed a fairly steep half-mile communications tower maintenance trail up a smallish mountain near Casa Grande, AZ in 108* June weather with the a/c on in 4-L. The temperature gauge never climbed above 225* and quickly recovered once I reached the summit and let it idle. I no longer own that '93 SE but it is still going strong with over 300k miles (it had over 200k when I made the climb). Would I do the conversion again? No... I don't think it's really necessary. The '99 SE I drive now got a brand new higher capacity Mishimoto aluminum radiator, stock t-stat & water pump, and ZJ fan-clutch -- she cools like a dream with the a/c on in 100* weather.
