Slonopotam
NAXJA Member #1358
- San Jose
4.0, 2 door, 4wd, manual transmission, 202000 miles.
Clean title, current registration. Smogged Autumn 2016.
- 3.5” Rubicon Express lift kit full leaves (RE6030?), adjustable upper arms(RE3780?)
- NP231 transfer case
-- Teralow (/4 low gear)
-- tera2low
-- Novak shifting (unfinished)
- Tom Woods rear drive shaft
-- Slip yoke eliminator
- D30 high pinion front axle
-- Alloy USA shafts
-- 3.54 gears
-- Truetrack limited slip
- Chrysler 8.25 rear axle
-- Yukon shafts
-- 3.54 gears
-- Some sturdy diff cover
-- Bumpstop plates
-- Disk brake conversion(from 98 ZJ?)
- 31x10.5R15 BFGoodrich All-terrain tires
-- Full size spare
-- alloy disks with smaller backspacing
- Currie steering
- Wider exhaust pipes
-- 2 flex pipes welded in
- Armor
-- SBS plates
-- Side rails
-- Lower arm guards
- 2” receiver hitches front and rear
Work done in the last 3 years:
- New radiator, water pump
- New front shocks and steering damper
- New starter
- Exhaust header (Banks revolver?)
- New driver seat (Corbeau sport seat)
The bad, to the best of my knowledge:
- Paint
- Rock rush, dents
- Heater core leaks badly (not when the heater is off)
- Windshield is cracked
- Tires are practically bold
- Clutch works, but probably not for long, since it was never replaced
- Roof crossbar buttons might not work
- Carpet is long gone
- Headliner is sagging
- Left front upper bumpstop is dust
- Oil leaks around the engine
- Seat belts might not lock
I'll wait for a best offer for a week. Pictures are coming.
-- tera2low
-- Alloy USA shafts
-- 3.54 gears
-- Yukon shafts
-- 3.54 gears
-- Bumpstop plates
-- Full size spare
- Currie steering
- Armor
-- SBS plates
-- Side rails
-- Lower arm guards
- New starter
- Paint
- Rock rush, dents
