trippled
- colorado springs, co
I believe the ideal setting is 6 degrees less than driveshaft angle, but it looks good. Check your caster/ tire angles. If it's off you can reset that pinion to fix caster angle.
6 would be a big difference. Like ehall said, it's a compromise between caster and pinion. Unless you want to cut and turn your knuckles.
