5-90
- Hammerspace
Flexibility
Edify me...
Flexibility
A nas is a nas, you can't do anything else with it. If you have a linux box with a whole bunch of hard drives for storage you can not only do the nas thing but you can setup openVPN, ftp, etc and gain access to your nas from outside. Thats the first two things I can think of off hand.Edify me...
One of the other little goodies, don't go with full sized 3.5" drives, go with 2.5", they make enclosures that will hold 8 of those little puppies vs 3 full size and the enclosures can use a single SATA connector. the enclosure fits inside a normal 3 bay hole like you find on desktops.
I'll poke around on newegg, I think thats where I saw them though it might have been on one of the specialty USB sites.
I'm specing out a HP DL380 right now, dual quad cores with 8 of those drives, hot swap SAS.
I havent seen anything like that on newegg recently, but they do have these http://www.newegg.com/Product/Product.aspx?Item=N82E16817995001
Ive got one right now, it's nice to be able to remove any drive a any time, and I can still use 3.5" drives so storage is cheap.
yea, I like that, on the power connectors on the back, do you need to use ALL of them for 5 drives ? seems some of the reviewers were a bit irate about that.
Those are the ones I have.I havent seen anything like that on newegg recently, but they do have these http://www.newegg.com/Product/Product.aspx?Item=N82E16817995001
My Linux box uses all 5. My XP box currently only has 1. I'll add a second (RAID1) drive when I get around to rebuilding it.yea, I like that, on the power connectors on the back, do you need to use ALL of them for 5 drives ? seems some of the reviewers were a bit irate about that.
So, if all 5 drive bays are populated you need to use either the two sata power or three molex connectors ?My Linux box uses all 5. My XP box currently only has 1. I'll add a second (RAID1) drive when I get around to rebuilding it.
Edit: Oops... you're referring to power. I'm using both SATA power connections, and none of the legacy 4 pin Molex connections. And all 5 drives in the Linux box run well on that.
according to the spec yes... in actuality it doesn't work too well for devices that have specialized software or devices that sync. Most support channels will not help you if they find out a device is hooked up to a hub.
Yes. My Linux box has both SATA power connectors hooked up on the enclosure, with 3 250gb drives in slots 0, 1, and 2, and 1.5tb drives in slots 3 and 4.So, if all 5 drive bays are populated you need to use either the two sata power or three molex connectors ?
Will the 2 sata power connectors power all 5 bays ?
