CURRIE 9" CUSTOM REAR AXLE JEEP TJ, YJ, XJ or CJ SUPER LOW PRICING TILL END OF MONTH
RWKHausSupply
TILL THE END OF THE MONTH - $2999 WITHOUT PERCHES AND $3119 WITH XJ PERCHES SET AND WELDED.
GET A COMPLETE READY FOR PAINT AND BRAKE LINES, CURRIE FORD 9" REAR AXLE ASSEMBLY.
http://www.rwkhaussupply.com/magento/drivetrain/complete-axle-assembly/currie-9-customer-rear-axle-jeep-yj-or-xj.html
The Centurion notch back style heavy duty housing features a 100% new 9-Plus reproduction stamped 23" wide housing center with the humped and dimpled stock style rear cover, 3" x .188" wall D.O.M. tubes and late style large bearing housing ends. Custom built and mig welded to customer width and pinion offset specs., and comes with 3rd. Member studs installed, and the 3rd. Member gasket, nut, and washer kit.
You get a heavy duty Yukon drop out filled with all of Yukon's highest quality parts, including:
*31 spline or 35 spline Yukon premium Zip Air locker with their incredible warranty.
*HD 31 or 35 spline iron case rated at over 1200HP.
*Iron daytona pinion support
*Gear ratio of your choice
*Setup kit with solid pinion spacer, not crush sleeve.
*1310 forged yoke
*Explorer Disc brake kit
*Currie Performance axle package with your choice of bolt pattern. Axles are ready to install, with all bearings retainers etc pressed on.
*3rd member is setup and ready to go.
This is a complete ready for paint and finial assembly of the 3rd in to the housing and shafts bolted in.
WE OFFER MANY OTHER AXLE PARTS.
EMAIL FOR BEST DEAL
Re: CURRIE 9" CUSTOM REAR AXLE JEEP TJ, YJ, XJ or CJ SUPER LOW PRICING TILL END OF MO
Ok, maybe I'm dumb, but whats does front end mean ?
To me, it means a front axle....
description from your website
JK-F9300F JEEP WRANGLER JK F9 FABRICATED 9" 1-TON FRONTEND UNIT - BOLT-IN
