I have an intermittant charging issue with my 97 cherokee. Upon starting the engine the gauge reads 12 volts. As I drive it, dash gauge suddenly drops to 9 and check gauges light comes on. I have a digital volt meter plugged into cigarette lighter that tells a different story. It reads 12.?? when I start engine, but slowly drops as I drive. It seems that when it gets to 11.70, the dash gauge immediately drops to 9 and the volt meter then jumps to 13.63-13.78. After it shows as charging for several minutes, I find that if I turn engine off and restart within an hour or so, the dash gauge will read correctly again.
Has anyone had this? All the other charging problems I searched out did not show anyone checking with DVOM. According to meter and bench test, my alternator is good.
Does dash gauge get voltage from PCM, ALT, or BATT?
Thanks for helping!
Thanks for helping!
