Xhavier_5478
- Colorado Springs, CO
I am in need of some advice or onsite expertise, my cherokee has the Crown Victoria rear disc swap on a Dana 44, and the WJ big brake swap up front. I set it all up, added ZJ spring and internals to my prop valve, bled the system, and things were great. Since this is a jeep I've been working on about 5 different projects on it at anyone time, well it sat for a few weeks while I worked on other issues, when I went to drive it the next time the brakes were dragging, so I pulled the rear wheels and both calipers were extended, so I pressed them back in with a c-clamp and did the same in the front, drove fine after that. Let it sit for a week or two again this time only the fronts, so I figured they were bad calipers from the Pull and Pay so I should replace them and get new ones, did that, bled the system and they were fine, fast forward a few months my jeep sat while I was doing my drive train swap, it did it again I forced the rear piston in and it was fine.
Last night after the jeep has sat 3 weeks, I actually had to bleed off some fluid from the rear caliper to force the piston back in, and the front wouldn't retract till I let some fluid out of it also, after that all are fine.
I'm going to check them again tonight and see if they are the same situation.
The question is why would they accumulate pressure from sitting?
Does anyone run the Crown Vic disc/WJ disc combo, and did you have to go to a different Proportioning valve all together?
