angryjeep
- Charlotte, NC
After searching the internets twice with google, bing, yahoo, hotbot, lycos, and manually with a comb... I figured I'd quit lurking and ASK for help.
So, here's what I've got: Daily-driven 2000 XJ, 4.0, Auto, Silver & Black, Winch-bumper w/out a winch (it holds tools nicely-- bangs knees even better).
The stalling problem is very very specific. Here's the rundown:
I suspect that winch-less winch-bumper is the root of the issue-- but that expenditure was shot down by my Wife. Additionally, I've read dozens of, "I've replaced every sensor twice" threads... if I could afford to do that, I wouldn't be driving an XJ (or would be driving one with a winch).
It will literally idle perfectly for 500 feet, rolling down-hill on the slightest of declines at nearly-nothing MPH, but as soon as it hits 0MPH: CLICK-ugh-ugh-STALL.
I've considered disconnecting the electric fan, to rule it out-- but given the whole 'overheat == blown radiator * warped cylinder head' equation; I'm somewhat timid about that line of troubleshooting.
I would really LOVE to see a flowchart or document that outlines in granular details the order of operations of the Jeep OBDII system. Something that says, "read speed sensor, when at 0MPH do XYZ." If such a thing exists....
Anyhow... I appreciate any advice you can offer.
-angryjeep (aka Kevin)
- It does *not* stall during the winter
- It typically stalls during warm weather
- It idles GREAT so long as the car is moving. Does not stall even when going 0.5MPH
- As soon as speed hits 0MPH, LOW IDLE and/or STALL.
- Two-foot application of brake/accelerator will overcome the stall.
- Low idle / stall is not accompanied by lurching, jerking, or any other trans-type indicators
- Still stalls when Trans is in Neutral
- Stall is sometimes preceded by a <CLICK> sound from under the hood (Electric fan engaging?)
- Driving without A/C reduces frequency of stall, but marginally so
- IAC *sometimes* will adjust, overcome the stall, and settle at normal idle (in noticeable increments)
- CEL IS CLEAR and CODE FREE
- New Champion Copper Spark Plugs
- New Coil (THAT brought the idle up some... didn't fix stalling)
- New Radiator (following overheat due to leaky hose / low coolant... oops)
- Rebuilt Cylinder Head & New Head Gasket (coolant in exhaust due to oops)
- New timing chain (just because I was in there)
- New Water Pump, Thermostat, and hoses (to prevent future oopses)
- New blower motor (irrelevant, but nearly as difficult as the head-gasket job)
