Itotebikes
- East PA
Was pressing in an upper ball joint on my 2000 sport and I think messed up the hole pressing it in angled. Is this replaceable with out the entire axle? I'll try to upload a pic...
Are you using the correct angled install adapters ?
there are plastic pieces inside most ball joints you don't want to melt the cup.
I've tacked some fairly thin materials together and to avoid warping used a pump sprayer filled with water liberally. Wet metal never bothered the weld, it did keep the heat from traveling. I've also got a bucket of heat-absorbing gel that keeps the heat localized, but the water works just as well. I'd use three, quarter inch tacks and make sure they burn in well. Cast isn't easy to weld, hot welds and cleaning the soot/carbon off often helps get a decent bond. Welding it would be my last choice, heat transfer might internally destroy your new ball joint.I would just do a tiny tack, I'm a much better welder than I am mechanic. Thanks for all the advice in the oversized BJ's, didn't know that was an option. I'll start the research on that now.
I put in standard spicers after I took out the oversized moog. Put 4 tacks in each top, 50k still going strong.
