Adjusting and Checking the Tension on Your Serpentine Belt
oldbill
Michigan
How do the rest of you adjust and check the tension on your serpentine belt. I have a 2000 Cherokee and have tried using the NAPA guage, which is just like the gates guage, but I don't think I getting a good reading from it. There's not a good stretch of belt to use it on that I can get too. Don't want my belt too tight or too loose.
Thanks,
Bill
I use the krikit II gauge or whatever it is and find the longest section. Forget the spec off hand for what it should be.
This; the upper most section of belt from the PS pump left to the water pump(?). I tend to prefer setting to the lower end of the specified tension.
After letting the engine idle for 10 - 15 seconds I take a few measurements to be sure I am getting consistent results.
I set mine, then start the Jeep and rev it up a few times. If it squeals, I tighten a little more and repeat until it goes away. Not the most scientific, but it's always worked for me.
This.
Your 2000 should have a 15mm adjustment screw behind the power steering pump on the idler pulley bracket.
I think I go with the section between the alt and ac compressor maybe.
with a serpentine belt on most vehicles, they will need to be and feel tighter than V-belts. On the longest section you have (the way I do it) if you can easily turn the belt 90 degrees, it's not tight enough. A new belt will "feel" tighter than a used belt. A used belt is any belt after you have driven the thing for a day or two. If it's not screeching, and you think it's too tight, you can afford to loosen it a bit.
