Adjustable Cross-Over Shock Mount
JEEPZZ said:
I still think that it would be 10x stronger if they also would tie it in to the 'frame' rails like a shock hoop. Like I said, I shreded mine but I run a much stiffer shock because I wanted to keep my 'anti-sway' streetability, my off road wheel travel AND my cargo area intact.
Even though it kinda sucks you would have to additionally fab something that you had to buy, it seems it would be easy enough to extend the JKS setup so it would bolt to the frame rails as well.
It replaces the factory crossmember.
I run that mount with 2.5 Kings. It is made well and very strong, but you will never get the valving correct. Works fine for rocks and trail, but sucks for speed.
Bringing this back for the same 2 questions, hows the axlewrap and hows the sway on the highway?
