Good to know. Thanks for the correction!
From a Dodge RAM website. Some insight into the O2S goal voltages. Note the fuel economy statements. You probably see statements in the forums concerning fuel economy that the downstream O2S does nothing but monitor the CAT. Myth busted.
[SIZE=+1]Upstream Oxygen Sensor Goal Voltage[/SIZE]
From Star Center News #5, February 2000 - tests for those who have access to OBD II or OBD III code readers.
Since the introduction of OBDII with both upstream and downstream O2 sensors, the downstream O2 sensor has been used to evaluate catalytic converter operation and to control converter efficiency.
When looking at the upstream goal voltage, it should fluctuate above and below the normal center (.4 to .6 volts) based upon what the downstream O2 sensor is reading. The vehicle should be driven through all speed ranges when checking goal voltage. If the goal stays high or low all the time, a thorough check of the downstream oxygen sensor should be made. Be sure you check the sensor, wiring harness, connectors, catalytic converter, and inspect for exhaust leaks.
Although a MIL lamp may not be illuminated, there are instances when the downstream O2 sensor goal voltage is out of range, causing driveability problems or low fuel economy.
If the downstream O2 sensor tends to stay below center all the time, the PCM will adjust the goal voltage higher in an efforet to correct the low O2 readings of the downstream sensor. This can result in low fuel mileage.
If the downstream O2 sensor has a tendancy to stay above center, the PCM will set a low goal voltage which results in a lean fuel mix which can cause the engine to run hotter and aggravate a spark knock condition.
Sometimes a service technician will reset the PCM and take it for a test drive. The PCM does a recalibration after the reset, and the problem may go away until the PCM has completed a relearn of the system and then begins to attempt to correct for the downstream sensor error. If the symptoms reappear after several days of driving after a service is performed, check the downstream O2 sensor, the exhaust system, the wiring, and the catalytic converter. Note: a worn out catalytic converter can produce symptoms similar to a bad downstream O2 sensor.
