jeepguy72987
- rhode island
1998 xj 4.0 aw4 150k ish. engine has a header, upgraded injectors, cowl intake, valve cover rear main oil pan and oilfilter adapter gaskets done. has a flipped and twin sticked dana 300. it leaks and is a hard to shift but it works. usually just leave it in 4 lo. has a 78 f 250 8 lug 44 in front 5.38 gears lock right ruffstuff diff cover. clayton long arms around 6ish inches of lift brand new kevlar 35s. 78 ford f250 dana 60 rear axle 5.38 gears and a spool ruff stuff diff cover. 2x6 rockers. has two minor rot spots above rockers in rear. will need right rear door also. has jcr gas tank skid and roof rack and winch bumper. no winch though led light bar in front. led lights in back. trans temp gauage in center console. bedlined interior floor. durango steering box grand cherokee wj powersteering pump. rocksolid rear bumper. comes with a psc steering ram. has brand new adjustable rear shackles for extra i got a king pin 60 and a ball joint 60. have extra parts lying around for it to. im not going to part it out just yet.im barley on here so either text 401-626-7814 or email [email protected]. i most likley won't pick up phone call unless you text me first. just don't use it anymore. works real well in rocks.
