I'm selling my jeep. It is located in Allen, Tx
Email me if you have a question: [email protected]
I won't be here to answer question on thread
Want it now: $15,000.00
It will include every extra part I have for it and ALL the tools in the jeep I wheel with.
Listed on e-bay: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=330343463829
Here is same ad if you don't want to go look:
1995 jeep Cherokee - Started life as a 4 door XJ
General Info:
Street legal, in Texas
Warn 9500i winch in ORGS Front Bumper
Tube Doors – Built in Speakers and doors use stock door latch. Stock 97 and newer doors could be installed (not included)
Rear bed area has storage for tools and spare parts. Weather tight area, stays dry! Spare tire holder.
All tubed rear area which extends to front firewall section. Frame reinforcements from front suspension to rear suspension mounts. This is a true uni-body, tube and original uni-body is all tied (welded) together!
SuperNerf rocker protection – welded into uni-body tube system
Air tank and Gas can mounted on each side of Jeep included with sale.
SBS – Steering Brace System Installed
PSC Power Steering System using CJ Pump and large reservoir
Sparco Racing seats – Mismatch colors and Driver side one is torn
Front fenders and Body parts have Rock Rash – Big Time – This jeep HAS been Wheeled!
Odyssey 1700 Battery
Custom built center console with large storage area and cup holders!!!!
Engine / Drivetrain:
Stock 4.0 HO. Has air intake but the rest is stock. 109k approximate miles
AW4 Automatic transmission. Has switch on gear shift to select between 1st and 2nd gear.
Atlas 5.0 Transfercase – Dual Shifter
Front Axle:
Currie Dana 44 – 4.56 Gears – ARB Locker – WJ Knuckles - WJ 2 piston Calipers – CJ Rotors – Alloy Shafts with 30 Sp. Outers - Warn 5.5 HD Hubs with Locking Hub kit – 1310 CV Driveshaft
Rear Axle:
Currie 60 Rock Jock 3 – 4.56 Gears – ARB Locker – Disc Brakes – 35 Sp. Shafts - 1350 CV Driveshaft
Front Suspension:
Currie J-Arm Lowers – Single Upper Arm Large Johnny Joint Upper – (3 Link) with JKS Over Axle Track Bar – Custom Coils – JKS ACOS Pros – Currie Anti Rock Sway bar – Rancho 9000 Pro Reservoir Shocks
Rear Suspension:
Custom Deaver Springs – JKS Cross-Over Shock Mount – JKS Boomerang Shackles - Rancho 9000 Pro Reservoir Shocks
Tires and Wheels:
37” Maxxis Creepy Crawlers – 16 x 8.5 - 5 on 5.5 American Eagle Wheels with Champion Bead Locks – Have extra set of Rings for them too - Detachable rear mud flaps (not shown)
Extras:
Have misc Spare parts for this jeep all will be included. Also a Century Portable Welder will be included in reserve or better price sale.
General Info:
Front Axle:
Rear Axle:
Front Suspension:
Rear Suspension:
Tires and Wheels:
Extras:
