BEEJSTR
- Orange, Virginia
Ok, So I'll spare all the details, but I swamped my Heep last weekend in over 4' of water. Immediately got pulled out and changed plugs and wires and cap and rotor as well as air filter and let everything dry the best I could. Also pumped all water out of the cylinders. Suprisingly everything is working great, other than I'm only running on 5 cylinders. My #4 cylinder seems to be the problem. Whenever I pull the plug it's all black looking while the rest are clean. Replaced that plug and wire a few times and no difference. When I pull the plug wire off the dist. cap, it makes no difference at all. But when I reconnect it it arcs, so I obviously have spark. When I disconnect any other plug, it makes a considerable difference. Also, I pulled my #4 plug and put my thumb over the hole while someone cranked it and I have obvious compression. What the heck can my problem be? I'm almost thinking injectors, but that thought scares me as as I've never messed w/injectors before and the whole thought overwhelms me. ANy help would be greatly appreciated!!!
Oh yeah, '90 XJ Pioneer, 4.0, AX-15.
