Old October 8th, 2006, 05:45
Jeep_XJ Jeep_XJ is offline
Starter
My Cherokee didn't start that well a couple of days ago and yesterday it didn't start at all, I hit the starter a few times and it started right up. What could cause this? It's my dd, and hasn't really been in mud deep enough to get close to the starter. Should I change my starter? Anyone have a step by step? Thanks alot for any help.
Old October 8th, 2006, 06:08
Re: Starter
And the Jeep is a 99.
Old October 8th, 2006, 06:22
Gerr's Avatar
Gerr Gerr is offline
Re: Starter
worn internal bushings
Old October 8th, 2006, 06:26
Re: Starter
Yeah, no start again, I'm going to replace it, anyone have a step be step?
Old October 8th, 2006, 06:50
riverfever's Avatar
riverfever riverfever is offline
Re: Starter
-Disconnect the negative battery cable.
-Get under the Jeep and start taking off the wires that go to the starter (remember what terminals they go to).
-Remove the bolts holding the starter to the motor (should be 2).
-It should pretty much fall right out.
-Grab the new one and put it up in there and start putting your bolts back together.
-Re-attach the wrires.
-Connect negative cable to battery.
I don't think I missed anything. It's super easy.
-river
Old October 8th, 2006, 07:13
Re: Starter
What year starters can I use in it? (99)
Old October 8th, 2006, 07:20
riverfever's Avatar
Re: Starter
Not sure why you're asking that. Go to the store and tell them what year you have. Unless you're gonna look for one at the yard? I wouldn't even bother with a bone yard starter but I guess I'd look 97+.
Old October 8th, 2006, 10:25
chelms27's Avatar
chelms27 chelms27 is offline
Re: Starter
97+, just go to the parts store and get a good one since it is a 99.
Old October 9th, 2006, 07:44
Re: Starter
Got one and threw it in, runs great, thanks for the help.
Old October 9th, 2006, 07:51
riverfever's Avatar
Re: Starter
Glad you got it together.
Old October 9th, 2006, 08:25
CJ~Abuzer's Avatar
CJ~Abuzer CJ~Abuzer is offline
Re: Starter
I had the same issue that you had after some heavy mudding a few weeks back on my 2000. I would turn the key and the headlights would not even dim...like it was even engaging the starter. I pulled apart the starter and the brushes had some dirt and grit in them and they were being inhibited from the springs successfully pushing them down to the armiture. After I cleaned it with some carb cleaner (let dry completely before hooking it back up and putting power to it) and used some dielectric grease to lube it all up and it worked fine. I saved myself from spending $170 on a new starter.
Old October 9th, 2006, 09:56
mikeny59 mikeny59 is offline
NAXJA Member #300
Re: Starter
I rebuilt - actually just cleaned and lubed - the original Mitsubishi, picked up a pos and rebuilt/tested it, keep it as a spare. W/any lift over 4" and 31's it's easier to change out on the road than a flat. ditto w/alt. Have two optimas too. Overkill is not a four letter word.
starter butch cassidy Wanted: Private Party Only 1 September 9th, 2006 16:06
starter... jeepinxj05 OEM Tech Discussion 1 March 29th, 2006 15:21
s-10 starter fix y-townxj Non-Tech / Off Topic 2 March 23rd, 2006 12:26
Starter? DVM04 OEM Tech Discussion 6 March 13th, 2006 20:07
starter ? maineiac OEM Tech Discussion 7 December 9th, 2003 22:06
