Old March 1st, 2009, 14:15
TomSwift's Avatar
TomSwift TomSwift is offline
Never Change Transmission Fluid & Filter?
I left Pep Boys a little confused last weekend. I took my 98 xj there to have the serpentine belt replaced. While it was in there I figured it would be a good idea to have the transmission fluid and filter changed. I was told that if the fluid had not been changed within 36k miles it would be a bad idea to do it at this point. The old fluid would likely be heavier as it was full of sediment. Replacing this old fluid would cause the transmission to begin to slip.
After doing a quick search here on the forums I have found no posts about this. Any thoughts?
Old March 1st, 2009, 14:22
10334226's Avatar
10334226 10334226 is offline
Re: Never Change Transmission Fluid & Filter?
What transmission is it?
Old March 1st, 2009, 14:39
TomSwift's Avatar
I believe it is an AW-4 transmission.
Old March 1st, 2009, 14:46
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
As long as you use the recommended trans fluid you should be fine.
Old March 1st, 2009, 14:47
R_jeep's Avatar
R_jeep R_jeep is offline
B.S.
Old March 1st, 2009, 14:53
j-nut j-nut is offline
It can happen to cause it to slip. The dirt and debris that gets into the fluid can cause excessive wear and gaps that when you replace the fluid, the thinner fluid does not take up the gap. But it is very rare that changing the fluid will cause it to slip. I have changed many trans fluids that were black and over 100 thousand miles on the original fluid and never had any problems. In the many trans fluild flushes that i have done or seen done, i have seen 2 or 3 cars that it caused problems to. I have even seen a car take 3 trans flushes just to get the fluid to resemble red and it never had a problem. I would say do the flush. The odds of it causing problems is not worth the problems that not changing the filter and fluid. We recommend trans and filter changes about every 60,000.
Old March 1st, 2009, 15:21
birchlakeXJ's Avatar
birchlakeXJ birchlakeXJ is offline
What the heck??? That is total nonsense. The general transmission fluid replacement interval is 30k. So they are saying if you are 6k late, to NOT change your fluid? Okay; your first order of business is to never go back to that shop. That is just plain bad advice.
Now for your XJ. How many miles has it been since the last tranny fluid change? You may find some (including me) that might not recommend a flush of your fluid if it's been a ton of miles since changing fluid, but dropping the pan and replacing the 3 quarts that drain from the pan is safe. Use Dexron/Mercon III fluid. If you're ambitious, you can drop the pan and clean or replace the filter (screen).
Old March 1st, 2009, 15:48
winterbeater's Avatar
winterbeater winterbeater is offline
I don't buy that. I had heard that line, but changed my hard worked F150 Lightning fluid after 85k miles and it was fine. New fluid has to be better than old. To me it's similar to the yarn about not using synthetic oil in a high mileage engine. By the way, I changed the tranny oil to synthetic with no problems.
Old March 1st, 2009, 18:50
TomSwift's Avatar
I have never changed the transmission fluid since I got it, which was just under a couple of years ago. I know the previous owner took good care of it and before that it was a lease vehicle. If I had to guess I would say it has been changed at least twice maybe.
Old March 1st, 2009, 18:54
Boostwerks.com's Avatar
Boostwerks.com Boostwerks.com is offline
NAXJA Supporting Vendor
Originally Posted by R_jeep View Post
B.S.
Seriously. Thats the reason why they're working at pepboys.
99 XJ Sport Build Thread:
http://www.naxja.org/forum/showthread.php?t=1059015
Check out our website!
www.BoostwerksEngineering.com
Old March 1st, 2009, 19:44
It is not total B.S. I have been an ase certified tech for about 10 years now and have been working in a GM shop for 7 of those years. In that time I have either done or seen at least 1,000 trans flushes or filter changes. Out of those I have seen 2 start slipping. Also, 1 wouldn't even move out of the shop after just a filter change. They had well over 100,000 miles on them and had never been changed. It is rare that it causes a problem, but speaking from personal experience working on vehicals for a profession, it is possible. If it was well taken care of, it should not be a problem. Either way I would change the filter and if the fluid is very dark, I would flush the fluid also.
Old March 2nd, 2009, 00:17
ColoradoRaptor's Avatar
ColoradoRaptor ColoradoRaptor is offline
Headbanging Hillbilly
B.S.
X3 Change it for GOD sake!!
People crushed by law, have no hopes but from power. If laws are their enemies, they will be enemies to laws; and those who have much to hope and nothing to lose, will always be dangerous. Edmund Burke
Old March 2nd, 2009, 06:54
Billfaceeee's Avatar
Billfaceeee Billfaceeee is offline
I have not Confirmed, or I used a BAD email Addy
hahaha yeah, flush it and move on, case CLOSED!
Old March 2nd, 2009, 07:07
blk88 blk88 is offline
Don't they make transmission fluid for "high milage" vehicles that is a thicker viscosity?
Old March 2nd, 2009, 07:29
duke000088's Avatar
duke000088 duke000088 is offline
I was under the impression that these "high mileage" fluids were partial synthetics.
Try the DexIII first. If it's a sweet ride, you're done. If it slips (very unlikely), try alternatives.
I'm in the middle of a long overdue drain/fill transfusion. I keep a sample of the pan drain in little tubes so I can monitor the progress from old, brown to new, red fluid.
Transmission Fluid Change AfricaXJ6 OEM Tech Discussion 5 April 11th, 2007 07:55
change transmission fluid MR. XJ OEM Tech Discussion 17 September 28th, 2006 16:58
transmission and filter change woes the_bandit87 OEM Tech Discussion 3 May 20th, 2006 23:07
transmission and diff fluid change whosyourdaddy? OEM Tech Discussion 5 November 26th, 2004 19:05
aw4 fluid and filter change Poison OEM Tech Discussion 2 July 6th, 2003 10:11
