Old February 24th, 2009, 17:50
bigalpha's Avatar
bigalpha bigalpha is offline
Oh the huge manatee
How do you get the pulley off of the
water pump?
I got the 4 bolts taken loose, but can't get the pulley off of the face of the water pump. You can't get the water pump off w/o taking off the pulley.
You ever have those days when you're wrenching and you just can't get it to work right, then realize you're doing it all wrong? Yeah, today is one of those days.
1992 XJ, 4.0, AW4, D30/D35
Old February 24th, 2009, 17:54
rredalty rredalty is offline
Re: How do you get the pulley off of the
if you're replacing the h2o pump, I say try smacking the face of the pump GENTLY trying to keep from damaging the pully but it sounds like there is some corrosion built up holding it on.
Old February 24th, 2009, 18:01
bigalpha's Avatar
Oh the huge manatee
Yeah, I tried putting a wrench behind the pulley and lightly pulling on it to see if I could break it loose, but no worky.
I'll try the smack-technique.
Does anyone have a spare garage I could have? It's getting chilly out.
Old February 24th, 2009, 18:06
bigalpha's Avatar
Oh the huge manatee
Yeah, that didn't work.
Old February 24th, 2009, 18:07
Tell me about it, I called it quits when the battery died in my LED hat.
Let me go look at mine and see if I can come up with another idea.
Old February 24th, 2009, 18:08
bigalpha's Avatar
Oh the huge manatee
lol. My headlamp was getting dim so I pulled out the fluorescent worklight. Then, I got stuck on it, ugh.
Old February 24th, 2009, 18:11
Sorry Alpha, only other option looks like pulling the rad and using a pully puller on it. On mine I have 2 threaded holes for the puller, almost like a steering wheel puller set would work.
Old February 24th, 2009, 19:38
bigalpha's Avatar
Oh the huge manatee
NOOOO. Total suck. I realllllly wanted it done before Friday.
Old February 24th, 2009, 19:59
MELKORsXJ's Avatar
MELKORsXJ MELKORsXJ is offline
spray some PB Blaster on it... and call it a night. and spray some more in the morning too.
i just helped change a water pump last week... pulley was quite snug, but we were able to pry and tap it off...
good luck to ya...
Old February 24th, 2009, 20:02
bigalpha's Avatar
Oh the huge manatee
I'll do that, thanks.
I even got a brand new can of PB Blaster I need to use
Old February 24th, 2009, 21:14
Jess Jess is offline
You do have the belt off......right?
Old February 24th, 2009, 21:18
bigalpha's Avatar
Oh the huge manatee
Yeah, and I've got the four bolts unbolted too.
Old February 25th, 2009, 22:02
bigalpha's Avatar
Oh the huge manatee
Yay, I got the pulley off. After a blast of PB Blaster last night, and some gentle taps on the belt-face of the pulley, it popped off.
Now, to rotate the power steering assembly to pull the WP off.
Seems like there's a lot to do just to replace the two parts. Jeez. Hopefully get it done tomorrow.
Old February 25th, 2009, 22:15
MELKORsXJ's Avatar
on the power steering assembly, only loosen the lower bolt behind the pulley, and remove the top two (there's a hole in the pulley to stick your socket through) there's also a bolt on the block that holds part of the PS bracket... i removed the air box to make more space. (was also replacing both radiator hoses at the time)
FS: gen right ps pulley piecebypiece SoCal For Sale 3 March 11th, 2009 00:10
AC pulley furrymcmonst OEM Tech Discussion 5 December 12th, 2007 11:46
pulley? sWissfoo Midwest Chapter 0 August 2nd, 2007 18:21
Fan pulley for 01' XJ.... RockRod Wanted: Private Party Only 0 September 20th, 2004 20:57
Idle Pulley or Pulley Problem SnowyXJ OEM Tech Discussion 3 November 11th, 2003 08:51
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
