Go Back   NAXJA Forums -::- North American XJ Association > Vendor's Marketplace > Vendor Advertisements
Old September 25th, 2008, 10:20
Rock Yacht's Avatar
Rock Yacht Rock Yacht is offline
NAXJA Member #1242
Original HD Chassis Stiffners > $135 shipped
New price for the original 7g (3/16" Steel) Chassis Stiffner, not a undersized imitation.
$135.00 shipped anywhere in the lower 48. Always in stock! No group buys or preorders needed to fund the next batch. Our HD Chassis Stiffners are IN STOCK!
All Chassis Stiffners ship in 3 business days or less.
Don't settle for an immitation, get the original!
T&T Customs, Inc. Master Your Terrain
Members get 10% off their Order!
Old September 25th, 2008, 11:34
bcmaxx's Avatar
bcmaxx bcmaxx is offline
Re: Original HD Chassis Stiffners > $135 shipped
t+t has no predrilled holes right?
Old September 25th, 2008, 12:43
CanMan's Avatar
CanMan CanMan is offline
Does this include free shipping? Can you drill a bunch of holes for plug welds also? How much do they weigh?
Old September 25th, 2008, 12:52
shortxjdoug's Avatar
shortxjdoug shortxjdoug is offline
x2 do they come predrilled for rosettes?
Old September 25th, 2008, 12:56
Smittty9785's Avatar
Smittty9785 Smittty9785 is offline
how come i cant find them on the site. i only found the unibody stiffeners for $99?
Old September 25th, 2008, 13:15
crazyjim's Avatar
crazyjim crazyjim is offline
That's them... They're selling for 135 shipped.
Old September 25th, 2008, 19:56
Rock Yacht's Avatar
NAXJA Member #1242
No need for rosettes, swiss cheesing the stiffners to rosette them on will create to much heat transfer into the sheet metal uni-body causing stress fractures over time. Buyer beware...
Our stiffners have been on our XJ(s) from the start of our business over 4 years ago, they are one of the first products we saw a dire need for and made right away. Our Jeeps are wheeled hard in CO (including Montrose) and Utah (including Moab). We drive it everyday and to the trail. The entire Jeep is inspected on a regular basis and to date the stiffners with just a perimeter stitch weld have and are holding up just fine. We even have our Rock Rail mounting feet welded to them which adds to the load they see.
Don't buy into the hype, rosettes are over rated in this application.
Bob
Old September 25th, 2008, 20:28
ECKSJAY's Avatar
ECKSJAY ECKSJAY is offline
Water is dirty
Bob
My XJ with an angle iron setup is just bolted on...and has been that way since the rig was built in 2003. By not welding it, the idea is to have some 'give' and to prevent stress cracks from being 'too' stiff...and to keep from producing cracks from heat as Bob describes. Mine's been through all the same stuff Bob's has, I'm sure, and it has held up just fine. It's getting the wire brush treatment this Winter and being repainted.
Old September 25th, 2008, 21:16
Gravesdiggerxj's Avatar
Gravesdiggerxj Gravesdiggerxj is offline
bs, if you weld it right, without overheating the metal, rosettes work fine, and are common practice in frame reinforcement.
That being said, you fellas make some fine products and I'd run them on my rig in a heartbeat, but unless you have an example of failure I'm sceptical of this particular statement...
Old September 26th, 2008, 06:46
Kittrell's Avatar
Kittrell Kittrell is offline
Agreed, sure you can do damage if you just shoot down the line and hit every hole at once. But if you take your time, and do it right, there isn't any more heat transfer than when you are doing the perimeter stitches. And I have also never seen a failure from that kind of additional reinforcement when done correctly.
Old September 26th, 2008, 09:24
Rock Yacht's Avatar
NAXJA Member #1242
I am not disagreeing with you and if done correctly by some one that actually knows what he/she is doing you won't hurt it - it being the sheetmetal uni-body. However, there-in lies the root of the problem.
DISCLAIMER: Not trying to ruffle anyones feathers...
Most consumers don't have the equipment or (if they do) the ability to use it correctly. Just because you bought a welder, doesn't make you a welder.
We try to make our installs as simple as possible without having the consumer be a full on fabricator. That's our job, haha.
Bottom line if rosette holes were needed they'd be in the part...
Bob
Old September 26th, 2008, 09:40
JeepFreak21's Avatar
JeepFreak21 JeepFreak21 is offline
Bob
So, in your opinion, when done incorrectly, stitch welding is less likely to cause a problem than rosettes? Or are you saying stitch welding is easier to do, or to convey in the instructions?
Billy
PS - I don't even remember if your instructions include stitch welding... I'm just curious.
Old September 26th, 2008, 09:42
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Can this be moved to a thread in tech or off topic? This doesnt particularly belong in the vendor area.
-Cal
Old September 26th, 2008, 09:54
Rock Yacht's Avatar
NAXJA Member #1242
IMO, any welding done incorrectly is a nightmare waiting to happen...
Stitching the perimeter is easier to do, less time consuming and less invasive on the uni-body. The factory used zinc coating on the under side for a reason... The more you weld on it the more the coating has to be removed to properly weld, not to mention boiling it off the back side...
Cal,
Sorry this has turned into more tech than advertisement. People have questions, so I am answerring them.
Old September 26th, 2008, 09:59
-Cal
Aren't you a mod here? [img]http://www.slicky.net/smilies/****.gif[/img]
I'd say, just move all the replies to a new thread in Mod Tech
Oh, and *cough* http://www.naxja.org/forum/showthread.php?t=967594 *cough*
Billy
Rate This Thread:
frame stiffners stuckinice Modified Tech Discussion 9 January 18th, 2008 13:08
Stiffners & Rust? Ty2003K Modified Tech Discussion 8 June 6th, 2007 18:35
TnT unibody stiffners New RWKHausSupply SoCal For Sale 8 August 4th, 2006 09:51
TNT Stiffners? algeroth79 Modified Tech Discussion 4 June 20th, 2006 08:17
