might need help
terryg
redlands
might need some help next weekend installing drop brackets (RE) - not sure yet. anyone close to redlands who has the tools & knowledge would be appreciated
There is a trick to installing the reinforcements without fighting the crossmember bolts. When you get everything bolted up, just before you put the crossmember back in force the reinforcement so the holes for the crossmember line up and then have someone drill a 1/8" hole up through them into the bottom of the frame and run a sheet metal screw in it. This will keep them in place when you install the crossmember which is real nice when you have to take it out down the road to do other work if need be.
Mike R
thanks guys - jay, u got that black xj i see all the time near tenessee & redlands blvd? i'm at pine ave in a townhouse
