Old April 6th, 2008, 12:48
ezsk8er ezsk8er is offline
96 xj clutch trouble
i have a 96 xj and have just raplaced the slave cylinder and hose, and i am now having troubles. i can shift gears fine, put it in gear take it out fine, but if i sit with the clutch in and with it in gear, for a little while just a couple seconds sometimes my jeep will start creeping forward, the 96 has no bleeder valve and i dont know that much about the workings of a clutch i tried taking the cap off and pumping to look for bubbles but nothing, i am at a loss, it has new friction plate any help is appreciated
thanks kc
Old April 6th, 2008, 13:17
Re: 96 xj clutch trouble
is there any way to bleed this system
Old April 6th, 2008, 14:36
94XJ2door5speed's Avatar
94XJ2door5speed 94XJ2door5speed is offline
No there isnt a way to bleed the system on my 94' I have to replace the whole master, hose, slave as a complete unit that comes prefilled and bleed. I need to do this too because i am leaking master fluid on the inside of the jeep not too fun.
Old April 6th, 2008, 14:40
CrunchnMunch's Avatar
CrunchnMunch CrunchnMunch is offline
Sorry to be off subject here,but does anyone know if the older renix jeeps have a bleed valve for the master cylinder? Mine won't build pressure a squirts all over the floor. (bought it like this) the plunger is bad in it,so I can just replace it with a rebuild right? And yea....getting fluid all over your pants sucks.
Old April 6th, 2008, 16:45
does n e one have any idea what my problem might be, how does a bad pressure plate act?
Old April 6th, 2008, 17:08
genlochlee's Avatar
genlochlee genlochlee is offline
Talking Re: 96 xj clutch trouble
A rebuild kit for the master should fix your problems sounds like a pressure drop from a bad seal, same goes for the guy who got the fluid on himself :P should fix you right up and its a REALY easy fix. Hope that helps.
Semper Fi
General Lochlee
Clutch trouble? -96JeepSpeed- OEM Tech Discussion 9 March 3rd, 2008 14:50
Major Clutch Trouble- Sorry So Long sidewys xj OEM Tech Discussion 15 February 12th, 2008 11:14
Trouble getting clutch line routed AvgJoe OEM Tech Discussion 0 March 5th, 2006 19:12
4.0 Clutch with Brand new Centerforce Clutch disc rav For Sale: Private Party Only. XJ ITEMS ONLY 4 May 11th, 2004 10:41
5 speed trans, clutch flywheel, clutch cyl rsalemi For Sale: Private Party Only. XJ ITEMS ONLY 2 April 28th, 2004 05:29
