Domino
- NW Georgia
After reading about the XJ owner in Virginia with his head aches with the local authorities, it got me wondering about the vehicle code in Georgia for lift kits and bumper heights.
I called the GA State Patrol Barracks in Rome and spoke with Officer Pledger about vehicle height and lift kits. There are several statues in the books that make the issue a little vague. As officer Pledger told me, if they think it looks unsafe, they can pull you over. If you look reasonably safe, they won’t be so inclined to bother you.
Georgia Traffic Code 40-8-6 states you can’t alter your suspension more than 2 inches either way, up or down, that is measurable by bumper height, based from the factory “recommendations”. Problem with that one comes under the definition of factory “recommendation”. So most don’t go by that. Also, there is a book with factory specs, including bumper heights for all vehicles used in the U.S., BUT- only one in a million GA State Patrolmen out there will even have that book, and that is out of shear personal desire to have that info handy.
The more recent code Georgia Traffic Code 40-8-6.1 categorizes it by weight:
<4500 lbs – 27” from the lowest part of the chassis to the ground
4501 – 7500 lbs – 30” from the lowest part of the chassis to the ground
7501 - 14000 lbs – 31” from the lowest part of the chassis to the ground
As put to me, every State Patrolman has his pet peeve. And if a specific GSP has a thing about lift kits, and wants to pull you over, he can if he thinks your vehicle is unsafe. And if that is the case, just be familiar with GA Code 40-8-6.1 and be mindful of your chassis height.
I have a friend who is a patrolman for the GSP, and he says he doesn’t bother with trucks with high lifts, as long as they are operating safely, all lights working, not DUI, etc, he said he doesn’t bother them. Although he said that some local officers have nothing better to do ..........
