Old November 24th, 2007, 10:37
citRon's Avatar
citRon citRon is offline
trackbar...redrill stock mount, drop bracket, or new adjustable bar?
Ok, BB w/ 2" coil spacers, front axle is sitting over towards the driver's side a bit. Should/can I redrill the stock mounting hole on the axle side with this little amount of lift -(would the new hole be enough away from the stock hole?) -how about a drop bracket- Skyjacker has one for $25, but it doesn't list how much drop or how far it moves the axle, or a cheaper adjustable bar? -mild, if any, wheeling. Lifted to clear my 30's. Thanks
Old November 24th, 2007, 10:42
Lowrange2's Avatar
Lowrange2 Lowrange2 is offline
Member# 2368
Re: trackbar...redrill stock mount, drop bracket, or new adjustable bar?
I'd say a new adjustable TB with an HD mount. But for the amount of lift you have you should be fine with just a adjustable tracbar in the factory mount... like the skyjacker trackbar.
Old November 24th, 2007, 10:54
JNickel101's Avatar
JNickel101 JNickel101 is offline
dont do the drop bracket...you'll end up with bump-steer...puts your trackbar at a different angle than your draglink
Old November 24th, 2007, 10:57
citRon's Avatar
oh, didn't know that. ok, drop bracket is out!
Old November 24th, 2007, 11:07
jkilcullen jkilcullen is offline
your best bet with a stock BB daily driver is to drill a new hole 3/4 of an inch center on center with the old hole directly to the right. It is easy, cheap, and it retains stock alignment angles.
Old November 24th, 2007, 11:10
also just make sure to not drill the hole any larger than the bolt requires. (ie dont use the existing hole to make your drill bit selection because it is more than likely wallowed out over the years)
Old November 24th, 2007, 11:47
citRon's Avatar
Perfect! That's what I was hoping to hear! 3/4" from center of old hole, mark for center of new hole, right?
Old November 24th, 2007, 12:03
xalexjx xalexjx is offline
i used a drop braket with four inches lift for about a year and didnt have any problems, but now i have an hd mount and adjustable trackbar,
Old April 21st, 2008, 14:48
citRon's Avatar
ok, 5 months later and I got around to doing this. Jacked it up, removed the Track Bar from the axle. With the wheels off, axle hanging, the Track Bar holelined itself up exactly 3/4" inch to the drivers side. Drilled a small pilot hole, then a 3/8" hole, bolted it back up. Easiest fix on this thing yet!
Old May 31st, 2008, 16:54
joeyschribar joeyschribar is offline
is your alignment now correct, also when the front axle is off center, will it pull the vehicle to one side?
im thinking about doing this and im at about 3 inches of lift.
adjustable trackbar and mount? Jimbo_1321 Wanted: Private Party Only 1 October 22nd, 2007 00:31
Best way to remove the trackbar from frame bracket/mount? glennv OEM Tech Discussion 6 March 4th, 2007 12:51
WTB: RE HD adjustable trackbar and bracket or similar horizontal mount bar downshift1 Wanted: Private Party Only 4 January 30th, 2007 20:42
re trackbar, mount, and drop bracket TheManch NAC Classifieds 0 July 29th, 2006 08:31
drop bracket/trackbar issue? BillR Modified Tech Discussion 8 September 9th, 2003 10:40
