Old June 8th, 2007, 16:50
xplorer29649 xplorer29649 is offline
42s w/ re 5.5
how much cutting do you have to do to fit 42" iroks on a 17x8 wheel with full widths and a re 5.5 long arm
Old June 8th, 2007, 17:00
CROSBIKE's Avatar
CROSBIKE CROSBIKE is offline
Re: 42s w/ re 5.5
cant u run 42's stock?
XJEEPER's Avatar
XJEEPER XJEEPER is offline
NAXJA Member # 13
Re: 42s w/ re 5.5
This should about do it...........but with 5.5" of lift?
you'll need to trim more...........
How about this?
Speak the Truth-Question with Boldness-Speak without fear.
Old June 8th, 2007, 17:15
DaffyXJ's Avatar
DaffyXJ DaffyXJ is offline
NAXJA Member #929
Re: 42s w/ re 5.5
Yeah on the D30 and Corp8.25, no problems.
Old June 8th, 2007, 17:21
CROSBIKE's Avatar
Re: 42s w/ re 5.5
i prefer using the dana 35 for its added strength
Old June 8th, 2007, 17:29
xjj33p3r's Avatar
xjj33p3r xjj33p3r is offline
NAXJA Member #1108
Re: 42s w/ re 5.5
Well, divide 42 by 2, you get 21. From the center of your hub, grab a tape measure, and see where 21" touches the body while moving it in a clock-wise fashion. That way you can always figure out what size tire you can fit combined with the amount of cutting you are willing to do.
But lemmy tell ya, there is so way in hell you are fitting 42s comfortably, or even packed in on a 5.5" lift.
Old June 8th, 2007, 20:18
Lukipela's Avatar
Lukipela Lukipela is offline
Re: 42s w/ re 5.5
Old June 8th, 2007, 22:41
CrazyXJ CrazyXJ is offline
Re: 42s w/ re 5.5
I have 38.5"s on full width and 12"s long arm lift I had to trim alot to flex alot
Old June 9th, 2007, 06:38
CROSBIKE's Avatar
Re: 42s w/ re 5.5
Originally Posted by Lukipela
thank you thank you ill be here all week
Old June 9th, 2007, 07:50
gregmondro's Avatar
gregmondro gregmondro is offline
Re: 42s w/ re 5.5
we definitely need pics when this is done. what axles will you be running?
Old June 9th, 2007, 08:13
TrueBlueXJ's Avatar
TrueBlueXJ TrueBlueXJ is offline
Re: 42s w/ re 5.5
I'd like to see 42s on 5.5". I'm sure the resulting crunch the moment your axles flexed in either direction would be down-right hilarious.
Old June 9th, 2007, 08:34
2xtreme's Avatar
2xtreme 2xtreme is offline
Re: 42s w/ re 5.5
I have about 4" of lift (sagging 4.5" lift with heavy bumpers, skids, winch, etc). I have trimmed about as much as you can on a 4dr (past the pinch seams)with out moving either axle forward or aft. I am willing to bet that I could fit 37's with reasonable flex (not great flex). In order to get to 42's you are going to want to extend your wheelbase to make more room for tires. I think you might end up with more than 6" of lift, but I think you might be able to do it with maybe closer to 8" or 10" if you trim excessively and don't expect too much up travel. I assume you understand that the "frame" is going to need some significant strengthening??
Michael
Old June 9th, 2007, 08:36
EvanH EvanH is offline
Re: 42s w/ re 5.5
just wondering, not to hijack the thread, but how much does a 42 inch tire weigh????
Old June 9th, 2007, 08:50
scorpio_vette's Avatar
scorpio_vette scorpio_vette is offline
Re: 42s w/ re 5.5
AAALLLOOOTTT...........actually i've never had the pleasure of being around a 42" tire, but i've lifted enough 33's, 35's and one set of 38's on steel wheels that i wouldn't even want to imagine trying to move a 42" tire by yourself. lol
Old June 9th, 2007, 14:12
mattyj's Avatar
mattyj mattyj is offline
Re: 42s w/ re 5.5
Are you serious??
