Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Jeep Picture Showcase
Jeep Picture Showcase Just a place to post (show off) your Jeep or your modifications images.
Old April 29th, 2007, 07:10
Sporko Sporko is offline
Talking Project Time
Well, today is the day I'm starting the big project...getting my jeep running.
The engine is in rough shape so a rebuild is what we decided to go with. The goal for today is pull the engine.
Specs: 1990 4.0 Laredo, 150,000+
Future plans...4.5" lift, 33"s , axle swap, etc etc.....
Old April 29th, 2007, 07:27
prb24's Avatar
prb24 prb24 is offline
Re: Project Time
Good luck!
Old April 29th, 2007, 09:41
peeweexj peeweexj is offline
Re: Project Time
Looks like a good candidate to fix up.
Much rust at all?
Is that a Ford 8.8?
Old April 29th, 2007, 20:05
Re: Project Time
Well, things went surprisingly smooth. Only had to go to the parts store once to pick up some sockets.
There is a little rust but nothing bad at all.
8.8 is correct. I found a guy on craigslist selling it for a good price that I couldn't pass. It will be a few months before it goes on though.
Old April 29th, 2007, 20:15
rehab's Avatar
rehab rehab is offline
Re: Project Time
looks good. im sure getting those bell housing bolts off was really fun. i normally take the whole front clip apart and remove the trans and t case with the motor.
your picture reminded me of when i pulled my engine the 2nd time.
Old April 30th, 2007, 11:14
Re: Project Time
haha...nice helmet
Those bolts sucked....a lot. ugh.
If /when I pull the engine out again, i'll probably do it your way. First time I've pulled an engine, live and learn.
Old May 2nd, 2007, 02:02
glensxj's Avatar
glensxj glensxj is offline
Re: Project Time
so far so good it looks like. thos bell housing bolts are a PITA its alot easier too get too them if you pull the head.
Old May 3rd, 2007, 13:40
MG2000XJ's Avatar
MG2000XJ MG2000XJ is offline
Re: Project Time
What is that thing going accross the underside of your hood?
Old May 3rd, 2007, 14:03
Ryno's Avatar
Ryno Ryno is offline
Re: Project Time
I am guessing that it is a worklight.
Old May 3rd, 2007, 19:25
Menzenski's Avatar
Menzenski Menzenski is offline
Formerly Mambeu
Re: Project Time
How difficult was it to maneuver the engine out with the front clip still on? I'm going to be pulling the 4.0 out of my 90 within the next few days, I think.
I may pull out the 4.0/AX-15/NP231 as one unit, though. Just weighing my options.
Old May 3rd, 2007, 20:36
jeepnuts311's Avatar
jeepnuts311 jeepnuts311 is offline
Re: Project Time
if you dont have access to awesome jacks and stuff, pull the engine and tranny as one piece, the engine lift will do ALL the work. i recommend using a rachet strap to "level out" the tranny otherwise the unit will hang at almost vertical cuz of the weight of the tranny. do, however, take the np231 off the tranny or you will never get it manuvered thru the engine bay. the t-case is easy to get off the tranny.
i pulled my front clip all the way off...that was the most tedious part of the swap, but with a 6" lift on 35s i couldnt lift the engine OVER the grille, i had to pull the front clip and i still had to let the air out of the tires to get the lift height i needed to clear the tranny over the bumper.
the only way he was able to pull the motor with the grille on is cuz he took the tranny off under the jeep, its so much easier (IMO) to take the tranny off layin in the driveway.
-Tim
edit: i dunno if i was clear enough, the reason i pulled the motor and tranny together is so i didnt have to fight to get the bellhousing bolts off while supporting the tranny and then having to manhandle it out from under the jeep.
Old May 4th, 2007, 13:12
Re: Project Time
It wasnt too bad getting the engine out, but if i do it again I'd take it out with the trans attached like Rehab and Jeepnuts311 said.
The bell housing bolts were a pain, but with the help of lots of extensions and cursing they came off.
As for maneuvering the engine, my friend was helping guide the engine as it was raised. Go slow and dont lower the engine on a fog light like me...d'oh
Rate This Thread:
Another project, this time a a toy Skullver Non-Tech / Off Topic 25 March 18th, 2007 18:41
Mechanical difference between part time and full time Mopar500 OEM Tech Discussion 9 December 22nd, 2006 13:25
Part Time 4wd vs Full time? KiwiXJ OEM Tech Discussion 13 March 6th, 2006 12:21
new project time Halewud Modified Tech Discussion 7 April 23rd, 2005 15:52
can you switch the part time light to full time ? Dano Modified Tech Discussion 9 October 9th, 2004 07:58
