Old March 5th, 2007, 11:23
Spidey's Avatar
Spidey Spidey is offline
Having a stupid attack - 32's on 2"BB
I'm having a stupid attack and have decided to run 32" Maxxis Bighorns on some cheapie wheels with wider backspacing. My rig has the 2" Rusty's AAL BB on it.
I'll trim the front & rear wheel wells as much as possible and do some extended bump stops front & rear (maybe limiting straps also).
Flex capability will be sacrificed, but I need ground clearance more than I need flex.
I can't spend any $$ on suspension and my tires are worn out.
All of my buddies are running at least 31's with 3.5" lifts and I just can't hang with them on the trails anymore so I gotta do something.
I don't want to buy 30's again (I'm hoping to get some XJ funds appropriated by June or July).
Does anyone have experience with this mod?
Old March 5th, 2007, 12:12
jfiscus jfiscus is offline
Re: Having a stupid attack - 32's on 2"BB
Yes, here is my XJ:
33x12.5 TSLs on 2.5:
33x10.5 Buckshot Mudders:
32x10.5 TSLs:
More pics here:
http://s25.photobucket.com/albums/c7...ep%20Cherokee/
I ran 33s on mine for a while before I went to 32s (got too good of a deal to pass up).
I got some TJ flares, positioned them as high up as I could, traced their location on the XJ & cut it to fit. I think it does great for where/how I wheel.
Old March 5th, 2007, 12:22
Spidey's Avatar
Thanks for the info and bonus pics!
Are the rear flares TJ's also?
I've seen TJ flares on the front wells, but never a good pic of the rear wells.
Great job!
Old March 5th, 2007, 12:33
Spidey's Avatar
Sorry... forgot to ask a question.
Are you using extended bump stops, or are you just flexin' 'till it rubs?
Old March 7th, 2007, 07:24
It flexes till it rubs, I try to pick a good line & don't have many problems with rubbing really. Stock bumpstops.
The flares are a set of front & rear TJ flares. I got them for free & painted them with Krylon Fusion.
3" and 32's????? XJ9888 Modified Tech Discussion 5 March 5th, 2007 06:31
RE 3.5" are 32's possible need4speedjp Modified Tech Discussion 3 April 6th, 2006 20:56
32's on 3" lift??? 87CherokeeChief Modified Tech Discussion 13 September 8th, 2004 13:32
3.5" with 32's..???? MC-92 Modified Tech Discussion 6 March 21st, 2004 12:56
Can I get away with 32's on 7" rims? trekker Modified Tech Discussion 3 March 19th, 2004 19:57
