scorpio_vette
- Milwaukee Wisconsin
ok. i finally got around to building myself a new engine using a 94Grand Cherokee 4.0L, but it didn't come with a distributor.
i got myself a distributor, but just wanted to get a little advice so i can hopefully get it pretty close on the first time.
what i know so far.
get #1 cylinder TDC, then install distributor align rotor (i was told i could face the rotor anywhere i want to and then install the plug wires in the firing order starting the #1 wire where the rotor is pointing. is that correct?).
i have a feeling that installing the distributor is made to sound alot more complicated than it is, but i just wanted to make sure i'm not overlooking anything.
if i do have it in wrong, the worst that would happen is it won't run right. correct???
what i know so far.
