FlyingL
- Phoenix, AZ
I have a lot of stock parts off of my 98 XJ (4dr.) Cherokee. These are all in excellent condition and would make great replacement spares for those of you who are still running stock parts. I have tried to make them CHEAP and a good deal. If you buy in quantity I have and will discount. I think they fit 90-98 but when you buy them they belong to you. I cannot be responsible for what Rigs they will work for. Here's the current list of parts which I have available.
1. D30 F&R axels (inner and outer).................................$55 each $100 set
2. Chrysler 8.25 Rear axels ...........................................$45 each $80 set
3. D30 Gears, (3:55) .................................................. .$50
4. Chrysler 8.25 Gears, (3.55) .......................................$50
5. Front Diff Cover, bolts included, D30 ...........................$15
6. Rough Country Swaybar Disconnects ..........................$20
7. Front Rotors (less than 1,000 miles on them).................$15 each $25 Pair
8. Stock Header, (Been welded by Greg at Mighty Muffler in
Phoenix, He's never had one break again..................................$100
after welding one in over 20 yrs.)
9. 12 Volt "Parts Master" Battery, 600 crank amps (1 yr old)...............$20
10. Stock Front upper Short Arms...................................$30 each $50 Pair
11. Stock Front Lower Short Arms...................................$30 each $50 Pair
12. Front Hubs including bearings....................................$30 each $50 Pair
12. IF YOU TAKE ALL ITEMS ABOVE................$500......(That's a $130 Savings!)
:exclamati YOU HAVE TO COME PICK THEM UP! I'M CLOSE TO THE 101 & CAVE CREEK ROAD IN NORTH PHOENIX.
