Old January 15th, 2007, 08:05
wildcar's Avatar
wildcar wildcar is offline
What fluid for a 5 spd?
My fiance's cherokee's tranny fluid needs changed and I was wondering what fluid to use. She almost has 200,000 miles so I was also wondering if there was any cleaners or tranney flushes I could use to help it out. She has a 93 sport 2 door with a 5 spd and a 4.0. Thanks for the help.
Old January 15th, 2007, 08:14
zipjeep's Avatar
zipjeep zipjeep is offline
Re: What fluid for a 5 spd?
75w90 gear oil 3.4 qts
Old January 15th, 2007, 08:32
RichP's Avatar
RichP RichP is offline
If it is an AX-15 and calls for GL3 lube you are limited to two, Dealer/OEM at $15 a quart or Redline MTS90 at around $11 a quart. DO NOT put a GL5 rated lube in there, it will eat the synchros.
Old January 15th, 2007, 08:42
wildcar's Avatar
where do I look to find out if it's a AX-15, is there a tag on it like the transfer case has?
Old January 15th, 2007, 08:50
zipjeep's Avatar
GL5 supercedes GL3 and GL4 it will say this right on the back of the can. API ratings are up graded every few years your owners manual will probably call for GL3 which was the API standard when the vehicle was made but is now replaced with GL5. Mitchell on demand calls for GL5 75w90. Regardless of what manual trans you have.
Old January 15th, 2007, 08:55
ChiXJeff's Avatar
ChiXJeff ChiXJeff is offline
Curmudgeon
zipjeep is *WRONG*. Even D/C has supported this misinformation.
GL5 oils contain sulfur which will corrode away the synchros.
I'll second the MT90. If it spends any time in cold weather, the synthetic makes cold shifting much more pleasant.
Post up what year XJ and what engine it's got, that'll give us a pretty good indicator of what transmission it has.
ChiXJeff
Lifetime member
"Jeeps are Cherokees. All other models are wannabes." Deb. K.
Old January 15th, 2007, 09:29
sflier sflier is offline
x2 on what Rich P. and ChiXJeff said. If you don't believe us, call up your local Jeep parts dept. and ask for Manual Transmission Fluid (it's GL3 spec ... i.e. it doesn't have the sulfur content that eats brass synchros). Or you can just give them your VIN number and they'll tell you that is what's called for in your AX-15 (and that is what you have in your '93 5-spd. if it's a 4.0). GL5 replaces GL3 and GL4 for most all purposes except for manual transmissions that have brass synchros like the AX-15. I have recently also seen it on the shelf at Autozone as Manual Transmission Fluid and has all this same info (about protecting brass components) on the bottle. Redline MTS90 is what I ended up using and it does the same thing but it's synthetic.
Old January 15th, 2007, 09:33
JeepDawg JeepDawg is offline
I have the T5 transmission and 160,000 on the clock (although the transmission is a bit newer). Anyway, the Redline MT90 is definitely top notch. As you have already discovered, there is a lot of controversy surrounding transmission fluid. With Redline MT90, you just CANNOT go wrong. It definitely improved the performance!
Old January 15th, 2007, 10:04
RichP's Avatar
NO, GL 3 does not superseed GL1 and 2, GL5 does not superseed GL1-4, it is not like the API ratings, the GL are specific ratings, mostly pertaining to sulphur content where it is used as a lubricant under extreme pressure like the ring and pinion gears in a differential where shear forces are enormous. Tranny gears don't have that extreme pressure to deal with. If a GL lube jar says they meed GL5 requirements and GL2-4 they are full of it, the GL3 rating specifies sulphur content [less then .01%] or almost zip point zero while GL5 has a pretty high content, high enough that you can literally smell it. So it teither has sulphur or it doesn't, no wiggling there, not until they come out with a 'smart bottle' that can say 'oh, sintered bearings, I'll keep the sulphur in the bottle'
GL3 and GL4 are close.
The sulphur eats sintered metal which is the problem. This is also true for other makers, Toyota and Nissan both use Asin warners in their stuff and the reqirements are the same, you can also get lube from them too.
Just to add one more thing, I run Mobil-1 gear oil in my 98XJ w/over 330,000mi on the tranny, I bought a case or two when I got the jeep new in 97. I've used it all up having 3 other wranglers with AX trannies in them and went to buy more,. The newer bottles say GL5, my older bottles say GL3. I replaced my backup stock with Redline MTS90.
Old January 15th, 2007, 11:20
CanMan's Avatar
CanMan CanMan is offline
Nope, wrong.
You would have an AX15, being that your rig is a '93. Ill give Redline MT90 another thumb ups. Good stuff.
Old January 15th, 2007, 11:43
PhotographerMike's Avatar
PhotographerMike PhotographerMike is offline
Related;
Do I need to run GL 3 in my '96 4 cyl with AX5?
Thanks,
Mike
Old January 15th, 2007, 11:46
lawsoncl lawsoncl is offline
Yet another vote for Redline MT90 or MTL if you're in a significantly colder region (better cold shifting).
Even the cheap GL3 from NAPA shifted like crap. So bad in fact that I thought I screwed up my AX15 rebuilt. My plan was to run cheap GL3 for a week after reinstalling the tranny and then change it out for the good stuff. After two days I switched to synthetic just to make sure it wasn't the fluid because it kept grinding going into first when it was cold. Synthetic made an immediate improvment and the grinding was gone.
Wildcar, your 93XJ 5-sp with a 4.0l is definitely an AX15.
... and before someone points out that the owners manual and FSM both call for GL-5 75w90 ... those manuals are incorrect and Chrysler has corrected it for their dealers. Again, if in doubt, give the dealer parts dept. your VIN and they will hand you bottles of Manual Transmission fluid made for the AX-15 and it will say GL-3 on the label.
Old January 15th, 2007, 12:00
5-90's Avatar
5-90 5-90 is offline
Not only is sulphur burning Hell on sintered metal, it's also quite rude to copper alloys.
GL-3 is also made by Sta-Lube - I've been using it for a while. It's rather cheaper than the Redline, Amsoil, or whatever other synthetics are out there - which makes it a plus for me (and Sta-Lube does make good lubricating oils and greases, I've noted.)
However, do check the bottle - if it doesn't say "GL-3" on it, don't get it. Just keep looking...
Old January 15th, 2007, 12:36
RichP's Avatar
Originally Posted by PhotographerMike
Related;
Thanks,
Mike
Yes, all the Asin warners in the AX series plus others need GL3. I believe the same is true of the NV series that went in in 99 or 00' but I'm not sure about that. I've not looked at my TJ owners manual or the FSM in respect to that but I would not be suprised if they had the same typo that the XJ's had.
can I use this fluid in my AW4? ryan2l OEM Tech Discussion 1 September 21st, 2006 13:17
OX Fluid jeepboy_90 Modified Tech Discussion 2 August 15th, 2006 17:27
What is the best aw4 fluid for here in So. Cal? silverslk SoCal Chapter 12 June 13th, 2006 18:39
atf fluid klonestar OEM Tech Discussion 8 April 18th, 2006 21:49
AT Fluid? pa_muddin_xj OEM Tech Discussion 9 July 26th, 2005 17:47
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
