Old July 5th, 2006, 17:45
newjeepowner newjeepowner is offline
Steering problem and noise. Help Please
I have a 99 XJ with 111,000 miles on it. When the Jeep is running and I turn the steering wheel i hear a hissing noise. While driving the jeep and turning around a corner. When i go to straighten the steering wheel out it almost feels as it pulsates while coming back to the home position. Fluid level is good. I just sucked out most the fluid about a week ago with a Turkey Baster. Refilled it with new Dot 3 fluid. Any suggestions?
Old July 5th, 2006, 18:06
Re: Steering problem and noise. Help Please
Not DOT 3. DUHH!!!
I just used Valvoline power steering fluid.
Old July 5th, 2006, 21:47
Blkxjkrawler's Avatar
Blkxjkrawler Blkxjkrawler is offline
Was it doing this before you changed out the fluid? have you bled all the air out? if not leave the resevior cap off and rotate the wheel back and forth from lock to lock a few times and see if that helps out. It kind of sounds like air in the system which can be a bugger to get out
Old July 6th, 2006, 03:04
No it did not do this before.
Old July 6th, 2006, 10:03
non-stick's Avatar
non-stick non-stick is offline
NAXJA Member #1288
Please tell me you didn't refill with DOT 3 Brake fluid.....
If you did, you have a problem that I wouldn't want to have to correct.
If you didn't then it sounds as though you just need to do a good bleeding of the system to get the air out.
Good luck
Old July 6th, 2006, 13:41
No I used power steering fluid. I had a brain fart.
noise from steering box? AD-8 OEM Tech Discussion 3 March 15th, 2005 09:20
Power Steering noise OKinNC OEM Tech Discussion 2 February 18th, 2005 08:17
Steering noise after lift boise49ers Modified Tech Discussion 2 January 21st, 2005 23:33
odd noise, something is going bad... steering? Kejtar OEM Tech Discussion 12 July 13th, 2004 21:33
Steering Noise Kurika OEM Tech Discussion 3 December 11th, 2003 21:44
