Go Back   NAXJA Forums -::- North American XJ Association > Bargains and Deals > For Sale: Private Party Only. XJ ITEMS ONLY
For Sale: Private Party Only. XJ ITEMS ONLY Private Party Ads only. If they even smell commercial, they will be deleted.
Old December 3rd, 2006, 17:35
98classic 98classic is offline
Built trail rig for sale
I just purchased this 91 xj a few months ago, but my financial situation has changed and I need to come up with some quick cash. Rig is located in Roanoke, VA.
White with black leather interior.
Pioneer AM/FM/CD
Sub box in rear for 8" sub (no speaker-if I find it you can have it)
New carpet
Center console with ZJ shifters
Runs 7" of lift with Long arms up front, leaf packs in back. Long arms were installed spring 2005 and the LCA frame mounts are still there. Uses a 5" coil and 2" spacer up front.
Bumpers front and rear swing away were custom built and are 1/4" plate. Rear has tire carrier, antenna mount, and license plate mount with light.
Flares are 4 rear TJ's, Front fenders and flares are cut, rears need cut. I have them but they are Not installed.
There is a homemade snorkle mounted outside, but the piping is not complete to the airbox. I have fittings and pipe to complete the project that go with the jeep.
Tires are 33x12.50 TSL Radials on 15x8 white wagons. One does have a plug, but does not leak at all. Spare is 33x10.50.
As a knuckle over steering system and RE trac bar that was moved up and over to compensate for the steering geometry changes.
Engine was NEW in 2000, Chrysler remaned unit installed by Hanover Dodge/Jeep. It currently has approx 22k on the engine. Transmission and t-case were remaned and installed at same time.
Has an SYE in rear and cv driveshaft.
Rear disc brakes from ZJ and functioning e-brake.
Dual diaphram brake booster and master cylinder from a 96 xj. Brakes work great. New calipers up front last month.
Odometer reads 107xxxk, please add 71k to that (Previous owner swapped out the gauges to get a tach).
Front and rear axles were rebuilt with new bearings and u-joints spring 2005.
Rear has an Auburn LSD.
Front is D30 high pinion, rear is 27 spline 8.25.
Windows were tinted, not the greatest job but acceptible.
Aux tranny cooler up front.
130/90 H4 headlight conversion with wiring harness. (YOU WILL BLIND PEOPLE)
Auxuliary lights front and rear.
Weather resistant CB radio.
Seperate Wiring harness installed for all accesories, fused and relayed.
4.0L Engine has run Synthetic since previous owner bought it and it runs LIKE NEW! Very Smooth. It does leak oil at the oil filter housing, but not a whole lot. You can get the o-rings at advance to correct.
Newer battery.
Rear tow hitch.
Front tow points.
Pretty much everything on the truck is either new or recently replaced.
Now the bad part...
Currently needs ball joints up front, a new johnny joint for the trac bar, and an alignment. It recently got a case of death wobble, and I just parked it.
The transfer case leaks at the back where the drive shaft hooks up. It doesn't leak fast, but it does leak and it spins onto the cat, so it smells pretty rough!
The rear cv driveshaft needs u-joints and a centering ball, as it recently got "angry sparrows".
Front swaybar is off the jeep. I have it, along with quick disco's. You would need to weld a tab onto the axle to hook them up. I've been using it as a trail rig, so I haven't worried about the swaybar.
Due to the no sway bars, and the need of ball joints, you will need to trailer this home.
I have $3500 in this thing, and would like to get as close to that as possible. So I guess asking price will be $3500 OBO. Please email me at Rick_Gabrielson@yahoo.com, as I rarely get on the forums.
Old December 6th, 2006, 12:09
Re: Built trail rig for sale
Open to offers..I need this gone BEFORE Christmas!
Old December 30th, 2006, 16:55
jeep is sold!!
GA: Built 99' XJ FOR SALE Matt99XJ For Sale: Private Party Only. XJ ITEMS ONLY 9 March 3rd, 2005 07:01
Built 8.25 for sale crazyoffroader For Sale: Private Party Only. XJ ITEMS ONLY 6 December 22nd, 2004 19:30
For sale 00 BUILT XJ shelbyluvv South East Chapter 2 June 15th, 2004 12:33
Built XJ for sale Led For Sale: Private Party Only. XJ ITEMS ONLY 13 July 14th, 2003 18:55
