Old February 10th, 2006, 20:15
jrice's Avatar
jrice jrice is offline
Question Noise from front axle?
I have tried to check the forum already on this subject but have failed in finding the answer. when I go to start my 98 XJ in the morning or after it has sat all day there is almost like a knocking sound comeing from my front axle but after the jeep has warmed up it goes away, I took my differential cover off and changed out my gear oil and while I was doing that I inpected my gears and they are all good, and the mechanic out here on the base said he thinks it might be my pinion bearings? What do you think and what are my other options on what it might be?
Old February 11th, 2006, 00:24
Midnight Krawler Midnight Krawler is offline
Re: Noise from front axle?
ujoints or wheel bearing
Old February 11th, 2006, 03:46
Sarge Sarge is offline
Are you saying the XJ makes this noise when you start the Jeep? Not when you start driving but when you turn the key and start it? If so I doubt it's the front axle. Please clarify when the noise occurs.
Sarge
Noobie question about Axle Seals in d30 Front (Leak?) wescam Modified Tech Discussion 13 September 8th, 2009 06:39
Front Dana 30 axle problems MAXJ OEM Tech Discussion 12 July 11th, 2005 20:39
Front axle noise in 4WD dj2790 OEM Tech Discussion 2 May 21st, 2005 08:43
Squeaking from front axle Citat3962 OEM Tech Discussion 7 March 21st, 2005 08:20
Is 3 peice front axle better than 2? jazclrint OEM Tech Discussion 9 February 15th, 2005 08:32
