Old February 5th, 2006, 15:01
Elwood Elwood is offline
Urgent Need Help With Ign. Switch Install
Determined That I Have A Bad Ign. Switch. I Know That It Is Located On The Steering Column. How Is The Best Way To Install It. Im A Virgin And Have Never Attempted This. I Have A 89 Cherokee That I Want To Drive Forever. Thanks.
Old February 5th, 2006, 16:24
tgregg tgregg is offline
NAXJA Member #1444
Re: Urgent Need Help With Ign. Switch Install
First off you need the star drives with the hole in them. The screws on the switch are fitted with special screws to help foil bad guys. The tumbler needs a lock smith and the electrical is a separate part. Each is about $100 at the dealer.
Just a note, when I thought my switch was bad it ended up being the nuetral safty switch. Does everything turn on? and it just won't crank?? Do your back up lights work??
Old February 5th, 2006, 17:11
langer1's Avatar
langer1 langer1 is offline
You don't need to mess with the tumbler at all, the whole switch is under the dash and operated with a cable.
You need to order the switch for tilt or standard. About $15.00 at NAPA.
Old February 5th, 2006, 22:21
lawsoncl lawsoncl is offline
It's actually a rod and not a cable. If it's a no crank issue, then I vote for the NSS as well.
Old February 6th, 2006, 07:25
langer1's Avatar
That depends whether you have a tilt wheel or not. Thats also why there are two switches, tilt wheels have a cables.
Switch & Relay Box Writeup (56k - better go get your boyz for help) FitchVA Modified Tech Discussion 39 October 18th, 2011 08:32
Rear dome light switch mhead OEM Tech Discussion 1 July 20th, 2005 21:27
Brake light switch? How does it mount? Ghost OEM Tech Discussion 3 December 1st, 2003 10:08
Urgent Motor/ Tranny help please!!! J Dubs Noling Modified Tech Discussion 4 April 14th, 2003 11:05
Headlight switch martin OEM Tech Discussion 3 March 31st, 2003 16:26
