Old January 31st, 2006, 16:10
tgregg tgregg is offline
NAXJA Member #1444
Just Turned Off
I'm reposting this to rephrase it. Today after running fine all morning the Jeep just turned off. Everything worked and it cranked over it was just dead. It sounded like when you crank the motor without the ignition turned on. After 30 minutes it fired right up. I did nothing but check all the PDC fuses. I'm scared now to take it out until I figure out what caused the problem as I don't want to get stranded. I'm thinking: vapor lock, auto shut down relay, ignition switch, or ??
Any thoughts?
Old January 31st, 2006, 16:12
4xBob 4xBob is offline
Re: Just Turned Off
That is classic CPS failure. It can be temperature dependant, cutting out when it gets hot. There are other possibilities, but CPS is the most likely.
Old January 31st, 2006, 17:00
NAXJA Member #1444
Re: Just Turned Off
What is a CPS?? All these initials are new to me.
Old January 31st, 2006, 17:50
NAXJA Member #1444
Re: Just Turned Off
OK, crankshaft position sensor. I went through all the possibles in the FSM index. Is that consensus guys? Gets hot, quits, cools off runs. I sure like my 69 CJ5 better and better. I can work on it!!
It looks like I need to buy a code reader if I'm going to work on this thing. It seems constant.
Old January 31st, 2006, 19:22
baldwins89xj's Avatar
baldwins89xj baldwins89xj is offline
Re: Just Turned Off
tgregg, i had the same problem with a 90 4cyl xj. once it was replaced(cps) it never gave me any more problems.i would say thats the culprit.
Old January 31st, 2006, 20:02
ChiXJeff's Avatar
ChiXJeff ChiXJeff is offline
Curmudgeon
Re: Just Turned Off
Almost certainly the crankshaft position sensor.
Mine crapped out on me a few years ago, at 70 mph in the center lane on I-94 southbound out of Milwaukee. No fun at all. Managed to get it to limp to within a few miles of home.
ChiXJeff
Lifetime member
"Jeeps are Cherokees. All other models are wannabes." Deb. K.
Old January 31st, 2006, 20:08
NAXJA Member #1444
Re: Just Turned Off
Thanks, a new one goes on tomorrow.
Old February 1st, 2006, 20:50
lawsoncl lawsoncl is offline
Re: Just Turned Off
BTW, a bad CPS will generally not set an error code.
Old February 2nd, 2006, 05:11
NAXJA Member #1444
Re: Just Turned Off
OK, I changed it out yesterday. By the way the dealer charged me $136 for the sensor. Now I just wait nervously to see if it fixes the problem. Seems like it should but until I get it real HOT I won't be sure.
unknown motor running after engine turned off ibjeepin821 OEM Tech Discussion 1 July 2nd, 2005 05:17
8.25" turned by hand does what...? Purple Modified Tech Discussion 13 April 17th, 2005 18:09
Spuddering when the key has been turned off. skog OEM Tech Discussion 7 September 16th, 2004 09:00
Can we get the img tags turned on in the Intermountain Chapter forum? Handlebars User Support, Questions and Suggestions 2 April 26th, 2004 21:52
Drums turned out of round vancebreck OEM Tech Discussion 3 October 21st, 2003 07:46
