Old July 14th, 2005, 04:32
xjjeepman's Avatar
xjjeepman xjjeepman is offline
np 231 t-case
I have a question! I have a 91 xj and I need to replace my np231 t-case. Can anyone tell me if a np 231 t-case out of a 97 tj will work in my 91 xj
Old July 14th, 2005, 04:53
Moore4X4 Moore4X4 is offline
Re: np 231 t-case
Your number one concern is going to be the spline count. Make sure that the input shaft on the T-case and the output shaft of the tranny are the same count. It would be better if the donor vehicle had the same tranny as your XJ, mainly for driveshaft lentgh matching...
Not sure if in 97 the TJ's had a driver output or a passenger output T-case. I know jeep seemed to enjoy changing stuff up mid-year.
Just my 2 cents...
Old July 14th, 2005, 23:45
Yucca-Man's Avatar
Yucca-Man Yucca-Man is offline
NAXJA Member # 683
Re: np 231 t-case
Just my 2 cents...
TJs use the same front axle configuration and NP231 t-case - driver's drop. The TJ will have a 23-spline input so you will have to verify the count on the output of your tranny...my understanding is that if you have a 5-speed it should be 23-spline as well but it could be a tossup if you have an auto...
231 transfer case kirby For Sale: Private Party Only. XJ ITEMS ONLY 1 September 4th, 2004 08:15
transfer case 242 vs 231 jeepinnurse Modified Tech Discussion 6 July 2nd, 2004 09:23
98 XJ 231 T. Case with RE Hack and Tap Cruzzin_XJ For Sale: Private Party Only. XJ ITEMS ONLY 4 June 27th, 2004 17:59
231 X-fer Case position switch Aloha365 Modified Tech Discussion 4 January 4th, 2004 09:26
..NP 231 transfer case studs,.. BILLXJ Modified Tech Discussion 4 May 8th, 2003 12:06
