Old June 14th, 2005, 14:09
GottaBeJeep GottaBeJeep is offline
I think I solved my overheating issue!
Well, I have been fighting with an overheating jeep for a long time now, and have replaced one thing at a time trying to find it. I don't have it fully assembled and on the road for a test drive yet, but I am pretty sure this is the problem, and it would always be the very last thing you fix.
Here's what I have put in: CSF 3-Row radiator, gone through several thermostats, new hoses, fan clutch, temp sensor, electric fan, electric fan rewired for in cab control switch. And I was still over heating. I would be fine on the highway, but idling or anything under 30MPH or under 1500 RPM's at that 30MPH and under would overheat. I thought, maybe it's the waterpump, but how could that be? It isn't displaying any of the symptoms of a ruptured pump, like the weeping or constant overheating no matter what. So I wondered, is it possible that the little fins could have corroded off? No way, it seemed like something was pushing the water in there, but it just wasn't pushing enough, especially at slow speeds/low RPM's. Oh well, not much else left to change, might as well.
Who would have thunk it? :rofl: The pump was still trying to work, just the fins had completely eroded off.
Old June 14th, 2005, 14:23
94XJ4x4's Avatar
94XJ4x4 94XJ4x4 is offline
Re: I think I solved my overheating issue!
Someone else posted some pictures like this a while back. My question is where do the little pieces go? Id be afraid they would be clogging some of the little water jackets up. Or maybe they break off so small it doesnt matter? Have you noticed any little metal bits in your coolant?
Old June 14th, 2005, 15:15
CRASH's Avatar
CRASH CRASH is offline
The little pieces clog up the small passages of your 3 core radiator.
CRASH
Old June 14th, 2005, 15:48
Rev Den Rev Den is offline
Further evidence that the stock cooling system WILL work....if maintained.
Rev
Old June 14th, 2005, 16:00
5-90's Avatar
5-90 5-90 is offline
Here's a "quick and dirty" water pump test - if you see that the engine is heating up at a stop or at idle, run it up to about 1800rpm or so. If it starts to cool off right away, your water pump is likely NOT the problem - the faster water circulation is what's helping to cool your engine.
This isn't 100% accurate, but it can help rule things out...
5-90
Old June 14th, 2005, 16:30
5-90
Actually, as you can tell by the pics, there is a little left there to cause some circulation, but only at higher RPM's, so, therefore, I just blew that theory right out the window, because that is what I thought all along until today. Whenever idling or low RPM's, I could put it in neutral and run the RPM's up and it would bring the temp down a little, because what was left of that pump was trying to push some more water through.
Old June 14th, 2005, 18:32
Eagle's Avatar
Eagle Eagle is offline
Lifetime NAXJA Member
Yeah, that'll do it!
Eagle - Lifetime Member
Owner/Driver/Enabler of "The Fleet"
Self-appointed President-for-Life of the World MJ Preservation Society
Old June 14th, 2005, 18:33
xjj33p3r's Avatar
xjj33p3r xjj33p3r is offline
NAXJA Member #1108
What about overheating that occurs during higher rpms? I've had my radiator cleaned out, flushed, new thermostat, but I have yet to check the water pump. Any ideas?
Overheating is not solved robs Modified Tech Discussion 64 July 3rd, 2005 16:02
How I solved years of driveline vibes. (long) DriverX Modified Tech Discussion 2 March 21st, 2005 18:23
Overheating issue......head gasket?? pressurerat OEM Tech Discussion 5 June 25th, 2004 09:09
XJ and garage door opener issue? C_M Non-Tech / Off Topic 3 December 7th, 2003 17:09
Overheating!! Headgasket issue? Maybe not?? scootin OEM Tech Discussion 10 October 29th, 2003 14:58
