490Chaser
- Columbus, GA
Yes I searched but it seems like I've been blessed with a unique difficulty. Everything was going fine and moving along with the BB... Everything is unbolted except for the front leaf bolt. I has come out part-way and seems to be stuck inside the bushing I keep hosing it with PB (because That's all I bought), I tried putting a pry bar on the bolt and turning it. I even put a gear puller on it while my buddy was shaking and moving the leaf around...I pulled hard enough to bend the puller. The leaf is loose inside the last hanger, the bolt is in the middle of the outside frame hole... it's not hung up on anything outside. I don't know how to get the bolt out. Can someone give me an idea? The axle is as low as the barke line will allow.
