ghettocruiser
- Norristown, PA
Hey everyone. I searched but didnt come up with much. I just bought a HP30 that already had 4.56s in it, boxed LCA mounts, and new balljoints, bearings, etc, etc. I believe the axle was from an 88 or 89. Great shape so far. Here is my question. I noticed the brake setup is different than my 94. Will I be able to bolt my calipers to the 88 axle brakets? If not...can I swap the brakets over? I just bought new calipers for mine so if I can still using them that would be cool. Both axles are non-abs, non-disconnect if it matters...
Im going to start cleaning the axle up tonight and give it another once over. Also...does anyone know how hard it is to re-attact the sway bar mounts on the axle? Or if there are any aftermarket mounts available??
Thanks in advance.
Justin
Thanks in advance.
Justin
