Old February 23rd, 2005, 18:47
Kejtar's Avatar
Kejtar Kejtar is offline
PostMaster General
Novak shifter for the 231?
http://www.novak-adapt.com/catalog/kit_sk2x.htm
Does anyone use it? Has anyone built anything similar? What do you think about it?
Old February 23rd, 2005, 18:54
BillR's Avatar
BillR BillR is offline
Toy Jeep driver!
Re: Novak shifter for the 231?
I have one installed in mine.
I mounted the shifter up high so it's easier to reach. I like it really well.
Old February 23rd, 2005, 18:55
Kejtar's Avatar
PostMaster General
Does it come with a boot or something that seals up that big hole?
Old February 23rd, 2005, 19:02
BillR's Avatar
Toy Jeep driver!
Excellent question Remi, and the answer is NO. The OEM felt on the cover plate wasn't enough to keep the road noise out, so I bought a shifter boot from a CJ and mounted it under the console plate. I DID keep the factory rubber boot that extends down from the hole, but there's enough missing from it now so it doesn't seal very well.
Old February 23rd, 2005, 19:03
Kejtar's Avatar
PostMaster General
factory boot? I don't remember seeing a factory boot in my 98 or 97: all I had in that hole was a metal shaped piece that the shifter resided in.
Old February 23rd, 2005, 19:07
BillR's Avatar
Toy Jeep driver!
My shifter assembly was in contained in a half-round rubber boot that screwed to the hump with the same screws as the shifter unit. The boot was the outer surface facing the driveshaft, and the shifter "tab" protruded through it.
Old February 23rd, 2005, 21:42
1990XJ4x4's Avatar
1990XJ4x4 1990XJ4x4 is offline
NAXJA Member #1158
Will that work in an old gen, that linkage comes apart every time I go wheelin and I usually end up covered in mud after shifting the t-case with a 14mm wrench. I think being able to not worry about that messing up is worth the $130. Has anyone ever fabbed anything like this up?
Old February 23rd, 2005, 22:25
Kejtar's Avatar
PostMaster General
After looking at the pictures and the tcase I got laying n the garage I think I'll take a stab at making one as it doesn't look too hard. Oh yeah... it should work on all 231's 242's and couple others.
Old March 4th, 2005, 11:32
1990XJ4x4's Avatar
NAXJA Member #1158
Well I finally broke down and ordered one, should be here this next thursday. I'll see if I can't take a few pictures and make a small write up of the install.
Old March 5th, 2005, 04:44
xtrememtbiker85's Avatar
xtrememtbiker85 xtrememtbiker85 is offline
thats sweet. i wanted something different so i picked up an extra shifter form the bone yard. then i cut the shifter at the bend of the handle and removed all the rubber grip. then i tapered down the shaft with a grinder. then i threaded it and i was done. i reinstalled the shifter and twisted on my 5 speed shifter. it looks sweet, functions real well and i can use almost any style shifter i want. i will pos pics later. plus it confuses ppl who get in my jeep who are unfimilar with it cause you have the auto tranny shifter nad to them what looks like a manual tranny shifter(dumb ppl).
Column to floor shifter swap question tcf26 OEM Tech Discussion 9 February 23rd, 2005 08:11
Can a stock 231 t-case survive behind a 4:1 Klune V with stock AW4/4.0L in a XJ? Big Red Modified Tech Discussion 11 February 20th, 2005 00:54
231 to 242 swap parts Nihil OEM Tech Discussion 2 February 4th, 2004 08:29
231 to 242 swap parts Nihil Modified Tech Discussion 0 February 1st, 2004 09:04
231 X-fer Case position switch Aloha365 Modified Tech Discussion 4 January 4th, 2004 09:26
