Old June 5th, 2003, 09:01
96country's Avatar
96country 96country is offline
Extended Brake Lines for RRO 2" BB
I will be installing a 2" RRO BB lift to my Cherokee this weekend. I was just wondering if I need to get extended brake lines? Other than this lift the rest of the suspension will be stock.
Thanks
Old June 5th, 2003, 09:07
bgcntry72's Avatar
bgcntry72 bgcntry72 is offline
On a Time Out
Simply redrill the fronts and mount the brackets 2-3 inches lower, bending the lines straight a little. For the back, a 95 YJ rear brake line is about $30 and will give you 3 extra inches, which ought to be fine for you.
Old June 6th, 2003, 05:20
bgcntry72's Avatar
On a Time Out
Talking Woo to tha Hoo
4* seems to be the Jimmy Thing.
About 1-2* below output.
Grinning like (more of a) madman.
Brake Noise Urban Redneck OEM Tech Discussion 0 December 5th, 2003 14:51
Spare Brake Lines Andy Steiner Modified Tech Discussion 4 November 20th, 2003 12:03
leaky RE SS brake lines FYR WOOD Modified Tech Discussion 5 November 5th, 2003 07:10
using TJ rear brake lines as extensions BLUTO Modified Tech Discussion 2 July 31st, 2003 22:50
Adapting extended SS brake lines. KarmirXJ Modified Tech Discussion 2 June 25th, 2003 07:44
