Old February 9th, 2005, 08:20
Spidey's Avatar
Spidey Spidey is offline
Voltage gauge not working...
...possible causes?
All other gauges are working properly.
Bad gauge maybe?
This is on a '92 XJ
Old February 9th, 2005, 08:23
Eagle's Avatar
Eagle Eagle is offline
Lifetime NAXJA Member
Re: Voltage gauge not working...
What does "not working" mean? The needle doesn't move at all? Or the gauge is not accurate?
Eagle - Lifetime Member
Owner/Driver/Enabler of "The Fleet"
Self-appointed President-for-Life of the World MJ Preservation Society
Old February 9th, 2005, 08:27
Spidey's Avatar
Sorry, forgot to specify.
Needle is dead, no movement at all.
Old February 9th, 2005, 10:21
Spidey's Avatar
Also forgot to add -
I pulled the gauge pod to make sure that all of the harnesses were plugged in and that the screws that hold that gauge in place are tight.
Old February 9th, 2005, 11:39
Eagle's Avatar
Next step (unfortunately) is probably to pull the gauge pod (again) and apply 12 volts directly to the contacts on the back of the voltmeter to see if that'll wake it up.
Old February 10th, 2005, 05:32
Spidey's Avatar
OK, I'll try that and see what happens.
Hopefully I just need to replace the gauge.
Thanks for the info!
Gauge lights not working?!?!? braeden Modified Tech Discussion 0 September 13th, 2004 21:49
fuel gauge not working right Weasel OEM Tech Discussion 6 July 6th, 2004 19:24
oem voltage gauge drops w/ warmup? JGXJ OEM Tech Discussion 5 February 18th, 2004 15:20
Help is not working Jeep'nD User Support, Questions and Suggestions 1 December 5th, 2003 12:19
Edit Profile Picture not working Jeep'nD User Support, Questions and Suggestions 3 December 5th, 2003 12:17
